Hey Skyline Family
Just wanted to see what everyone things about my build, I'm shooting for 600whp and reliable  (hahah) there is very minimal track or racing maybe 1 once a year.
The List :
Quantity  Make  Items  Part Number  Section  Have / Need
1 SAMCO Sport  Samco Sport - Rad Host Set Black  TCS37C- BLK  Cooling  Have
1 Nismo  Nismo Thermistat  21200-RS580 Cooling  Have
1 Nissan  Nissan Water Pump - N1 21010-24u27  Cooling  Have
1 Nismo  4inch Intercooler  14461-RS580 Cooling  Have
1 Koyo  Radiator  HH020214 Cooling  Have
1 Apexi  Apexi Power FC - Boost Controller  415-A013 ECU  Have
1 Apexi  Power FC - Djetro with software    ECU  Have
1 Wiring speclaties  Rb26 new HARNESS    Electrical  Need to buy on Nov 24 - Black Friday
1 Nissan  O2 Sensor Rear  22690-05U22 Engine  Have
1 Nissan  O2 Sensor Front   22690-05U21 Engine  Have
2 Nismo  Nismo Motor Mounts  11200-RS580  Engine  Have
1 Right drive  Oil Cooler Kit  Right Drive  Engine  Have
18 Autobahn  Autoahn88 Heater Hose kit  Ashk119-BLK Engine  Have
1 Nissan  Spring Tensioner  13072-58s10  Engine  Have
1 Tomei  Tomei Oil Restrictor  TB2040-NS05A Engine  Have
1 Nissan  Nissan Belt Tensioner  13070-42L00 Engine  Have
1 Nissan  Nissan Pully Assy Idle  13074-58200 Engine  Have
1 Nissan  Nissan Crank Gear  13021-05u10  Engine  Have
1 Pitwork  Pitworks - Accessory belts  4PK-950  Engine  Have
1 Pitwork  Pitworks - Accessory belts  4PK-925 Engine  Have
1 Pitwork  Pitworks - Accessory belts  4PK-880 Engine  Have
1 Tomei  Tomei Timing Belt  151051 Engine  Have
1 Tomei  Oil Pan Baffle Plate  193034 Engine  Have
1 Nissan  oil Pump - N1 15010-24u01 Engine  Have
6 CP  Pistons for Nissan RB26DETT 87mm 9:1  SC7314  Engine  Have
1 Fluidampr Phase 1 Crank pully  610901 Engine  Have
6 Spool  H-Beam Rods  8XPUVA1GBV Engine  Have
1 HKS  SSQV Blow off valve  71008-AK001 Engine  have
Set Acl Race main Acl race series 0.25 + clearence 7M2428HX Engine  Have
Set  Acl race rod Acl race series 0.25 + clearence 6B2960HX Engine  Have
1 Greddy  Greddy Exhaust T4 Manfold    Exhaust  Have
1 Custom  4inch Downpipe    Exhaust  Have
1 Garrett Garrett T04z Turbo A/R .70  740753-5002s Exhaust  Have
1 Custom  T4 Exhaust Gasket    Exhaust  Have
20ft Russell Fuel Line -10 Feed and oil return  632190 Fuel  Need
20ft Russell Fuel Line -8 Return  and Coolant Feed line for Turbo  632140 Fuel  Need
1 Tomei  Tomei Fuel rail  JECS-253001 Fuel  Have
1 Tomei  Tomei Fuel PSI Regulator L type  185002 Fuel  Have
1 AEM  AEM - Fuel Pump Intank  50-1000 Fuel  Have
1 Tomei  Tomei Metal Manifold Gasket Intake RB26DETT 131002 Gasket  Ordered RHDJapan
1 Cometic  Gasket Kit  PRO2017T Gasket  Have
1 Cometic  Lower Gasket kit  PRO2017b gasket  Have
1 Auto Staff Auto Staff Water Bypass Block - RB Engines AS-RBH Head  Ordered RHDJapan
24 Tomei  Tomei Solid Valve Lifters RB26DETT 163005 Head  Ordered RHDJapan
28 Tomei  CAM BEARING CAP STUDS RB26DETT 193016 Head  Ordered RHDJapan
1 Tomei  Tomei Camgear Exhaust  152010 Head  Have
1 Tomei  Tomei Camgear Intake  152009 Head  Have
1 ARP  ARP Main Stud Kit  Bolts  202-5403 Head  Have
12 Supertech  Supertech  Intake - Valve 1.0 + Nivn-1032 Head  Have
12 Supertech  Supertech Exahust - Valve 1.0+ Nevi-1032-7  Head  Have
1 Custom  Intake Plenumb 90mm / 14mm Throttlebody    Head  Have
1 Apexi  Apexi Head gasket 87mm / 1.5mm thick  814-N003  Head  Have
1 Tomei  Tomei Cams - 260° / 10.8mm lift - Intake  1421260108 Head  Have
1 Tomei  Tomei Cams - 260° / 10.8mm lift - Exhaust  1422260108 Head  Have
12 Supertech  Supertech Valve Guides - Exhaust  GDE-NSR7-ET Head  Have
12 Supertech  Supertech Valve Guides Intake  GDE-NSR6-I Head  Have
12 Supertech  Supertech Valve Seals - Intake  VS-N6I Head  Have
12 Supertech  Supertech Valve Seals - Exhaust  VS-N7E Head  Have
14 ARP  APR Head Bolts  202-4207  Head  Have
24 Supertech  Dual Valve Spring  SPRK_M1007D/RB Head  Have
1 Perrin  Perrin Gauge Pod  ASM-INR-305  Interior  Have
1 Apexi  Apexi - Oil Temp  APE-77817  Interior  Have
1 Apexi  Apexi - Oil PSI  APE-75210 Interior  Have
1 Apexi  Apexi - Water Temp  APE-28491 Interior  Have
1 Innovative  Wideband  3769 Interior  Have
1 Nissan  Oil Psi Sensor  25070-30P01 Oil  Have
6ft Russell Feed Oil Line -4 632010 Oil  Need
1 Spool  RB Spline Driven Billet Oil Pump Gears - Suit N1 Oil Pump U5XO0ETE6F Oil  Have
2 Driftwork Drift work Camber Arms Rear    Suspension  Have
8 AMS  Solid Rear Bushings    Suspension  Have
1 OS Giken  Throwout bearing  97015 Transmission  Ordered RHDJapan
1 OS Giken  OS Giken Strengthened MT Center Plate RB26DETT   Transmission  Ordered RHDJapan
1 Nismo  Nismo Transmision Mounts  11200-RS580  Transmission  Have
1 OS Giken  OS Giken TS2b  NS112-BQ6 Transmission  Have
1 Custom  Oil Drain Adapter - with Gasket - T04z    Turbo  Have
1 Russell Coolant lines for Turbo    Turbo  Ace tuning will build
1 Russell Fuel Filter  649250  Fuel  Have
6 NGK Spark Plug  BKR7E Ignition  Have
1 Nissan  Nissan Stud for Timing Tensioner   13073-V5001 Engine  Need
1 Nissan  Nissan rb26 tensionner bolt   Engine  Need
1 Nissan  Nissan rb26 tensionner washer   Engine  Need
1 Nissan  Nissan rb26 idler bolt    Engine  Need
1 Nissan  Nissan rb26 idler washer   Engine  Need
Any Advice is appreciated
Thanks Guys
https://www.sau.com.au/forums/topic/472529-1989-nissan-skyline-hnr32-build/
You haven't listed any injectors.
Given,for example, the Nismo I/C isn't needed and costs a bomb I can't work out your intent.  Sell the turbo and get something good,. It's probably the most important bit on the whole bill.
You list, to be honest reads a bit like its 1990. EG Apexi is old, old tech.
injector Dynamic ID1000,
the intercooler was used got it for $650 from a friend and same with Power fc its old tech that works.
    • Yeah, I guess its pretty easy to get to if this doesn't work. Just wait till next oil change and pull it out. I am going to have to do the oil pan gasket soon and thought I'd just replace it while I was there.  Thanks
    • All that matters is you're safe and you were able to type that post. Hopefully heaps of parts you can recover for the next shell.
