Well after napping most of yesterday afternoon I am now alive after a great weekend up at the Winton Skidpan day.
Thanks to all the competitors for a great day with no issues and to the committee members and everyone who helped out on the day. Days like this can't run without you all. We have a few things to tweak be I am sure we will be back next year for at least one event.
Here are Video's from Martin taken from the side of the track, if you wish to post these on social media please credit Martin Sullivan for his work. Anyone who want's to use them for business or promotional purposes needs to seek permission from Martin AKA @emts
If you have any video's or pictures fee free to post here.
Matrin's Video's and pictures
RESULTS
SAUVICMotorkhanaResults20171118-Final.xlsx
  • Like 2
https://www.sau.com.au/forums/topic/472718-sau-motorkhana-wrap-up-thread/
How did this compare to the events at DECA in the end?
I.e skidpan size, track time and such? Amount of runs?
Realise first time there's some kinks to work out but what was the vibe in regards to the venue?
skid pan is similar size, no back track however.
that said it's cheaper to hire so we are keeping entries down so you just get a heap of runs.
as for how much entrants got on Sat, we closed the pan 45 Min prior to the end of our hire time as every-one was out of tires or fuel...
so I call that successful.
  • Like 1
  • 1 month later...
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
