I’m going to be building my neo up soon with a top mounted gtx3076 gen2, 6 boost etc. Don’t intend to push for lots of power, just a nice road setup. On 98 Ron
I have what I believe to be a r35 gtr afm already, came with the power F.C., although I currently am tuned on the stock afm
if I want to use this gtr afm, I have read I need it in a 4” tube, is that accurate ? Or how have others mounted them. Also, is there much to tuning the power F.C. using the r35 afm or is it easy enough, will it limit my tune much or will it be a good job. Some tuners I have spoke to are trying to get me to go for a link ecu, but for now I have the pfc.
https://www.sau.com.au/forums/topic/472845-r35-gtr-afm/
I've tuned several R35 AFMs in both 3" and 4" inch tubes and also tuned the HPX R35 styled AFM...
The tube size just changes the resolution of the AFM, generally if you run before the intake I would go bigger and also introduce a bend to reduce turbulence. It's more preferable to install these AFMs post turbo, post FMIC to reduce any reversion issues as well as turbulence.
In terms of scaling the PowerFC to work with the R35 I have no idea (as I stopped playing with powerFC about 10 years ago - as they're outdated and have zero features).
Preferable to go with Nistune, that has all the data for the R35 AFM (literally there's a menu where you select your AFM vs. the pipe size), not to mention supports basic engine protection, full flex support and launch control (bang bang lol).
If I was your tuner and you brought me a R35 AFM to install on your car I would say get a Nistune OR sell everything and get a Link or Halaltech or Adaptronic
  • Like 2
https://www.sau.com.au/forums/topic/472845-r35-gtr-afm/#findComment-7861354
yeah, entirely up to you
I prefer Nistune for it's basic engine protection. You can setup a TP Load cut and you can set soft/hard cut RPM limiters so you won't destroy your oil pump.
Just my recommendation, I know PowerFC has it's "cool" factor as you have a hand controller - but the novelty wears off there for me
https://www.sau.com.au/forums/topic/472845-r35-gtr-afm/#findComment-7861398
Nothing to do with cool as such. I’ve had 3 power F.C. equipped cars before, one nistune, one emanage ultimate and 2 link g4 setups over the years... and I’ve yet to notice a huge pile, yes a link might have pulled a bit more power out of say the emanage setup, but all provided a safe tune
so seeing as I have the power F.C. in this car I’ll stick with it. For now
So... now that’s out of the way.. lol.
https://www.sau.com.au/forums/topic/472845-r35-gtr-afm/#findComment-7861423
So another question
car is currently mapped on a hks2530 to 1.35 bar on stock afm
When the new setup is installed, gtx3076 and top mount 6boost,  will I be able to limp to a tuner if I leave the stock afm in place. I mean limp, basic drivin. 3k rpm max.
Or will the map be so far out it will drive awful and risk motor damage
https://www.sau.com.au/forums/topic/472845-r35-gtr-afm/#findComment-7861534
  • 1 month later...
I’m not sure but I’m thinking a 3.75 or 4” pipe to suit my needs, with the extra air of the 3076, but I don’t want to go to big and loose to much low down resolution
could anyone advise on that?
and also, I have a tail on the plug from the r35 afm, is it only a matter of chopping my own cars afm loom plug and joining the wires?
cheers
https://www.sau.com.au/forums/topic/472845-r35-gtr-afm/#findComment-7865298
It's a hot wire air flow meter.  It works by running a current through a wire (or a transistor) and monitoring the temperature of that wire (or transistor).  Then the current is controlled up and down to maintain the temperature of the sensing element.  Heat is lost to the air flowing past the element based on the mass flow rate of air.  More air flow = more heat loss -- more current required to maintain the temperature.
In a turbo inlet position, the air is at atmospheric pressure, so is moving faster for any given mass flow rate.  In an IC pipe, the air (at high flow rates) is at whatever the boost pressure is.  Higher pressure = lower velocity for any given pipe size.  Could be double or triple the density of atmospheric air.  Regardless of what the pressure is though, the local air mass flow rate past the sensing element is what the AFM is reading.  More air = more blah blah blah, as above.
  • Like 1
  • Thanks 1
https://www.sau.com.au/forums/topic/472845-r35-gtr-afm/#findComment-7865331
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
