Hello!
Up for sale is my R34 GTT
I’ve considered selling this a couple times now, it’s a great car and it’s never let me down but I feel like it’s time to move on and get something a little more practical for road trips and skiing holidays.
I also have all receipts for all car related purchases and servicing performed, literally a whole folder full of paperwork.
The car has a whole lot of quality parts, time and money put into it, it's ready for anything you throw at it or ready to enjoy as a very capable skyline. This is an absolute blast to drive through the twisty roads or at track days as well as being incredibly reliable. Even though it's big and red, it's presented well and the police never give me any trouble.
Rego Expiry: 08-03-2018
Build Thread link can be found in my signature
Exterior
  • AR2 Paint in Great condition, 1 blemish on the rear bumper.
  • Viva Garage D1 Spec front lip
  • JSAI Z Tune Style Side Skirts
  • JSAI Z Tune Style Rear Pods
  • Genuine Nissan R34 GTR Rear Spoiler
  • Genuine Nismo Carbon Fibre Spoiler Blade
  • Window Tints front and back in 20% darkness
  • Enkei RPF01 Wheels 17x9+22 (Front and Rear)
  • New Goodride Tyres
  • Nismo front and side indicators
  • Xenon Headlights
Interior
  • Genuine Bride Seats with Genuine bride rails
  • Nismo floor mats
  • Nismo GT500 Shift Knob
  • Nismo 300km/h dash
  • Nismo center gauge cluster
  • Sony Head Unit  (bluetooth phone/audio with an under seat sub hidden in the boot)
  • Broadway Mirror
  • Working Heater/Air Con in great condition
  • All plastics in great condition, no sticky coating / peeling
Suspension / Handling
  • HSD Monopro coilovers
  • Nismo S-Tune Sway bar kit (Front and Rear)
  • Cusco Castor Rods
  • GKTech Hicas Lock Bar
  • Nismo Strut Brace with brake stopper (Front)
  • Cusco rear Strut Brace
  • Rear subframe removed and reinforced with GKTech weld in plates
  • Whiteline Subframe bushes
  • GKTech Diff Bushes
  • Nismo 1.5way LSD
Brakes (Front)
  • HEL Braided Brake Lines
  • DBA T3 4000 series slotted Rotors
  • Project Mu HC800+ Pads
Brakes(Rear)
  • Machined Rotors
  • Winmax Brake Pads
Engine Bay
  • Healthy RB25DET NEO
  • BLITZ SBC Spec R Electronic Boost Controller (Dual Solenoid Type)
  • APEXI SAFC
  • BLITZ Turn Flow intercooler connecting to stock piping (no issues with police)
  • Stock Airbox (Again, no issues with police)
  • Bellmouth 3” Dump Pipe with High Flow cat
  • HKS Silent Hi Power Exhaust 3” cat back
  • Alloy radiator with Greddy Radiator Cap
  • Water temp gauge hidden in glove box
  • Timing belt kit done
  • OS Giken cam gear (exhaust)
  • New OEM Thermostat
  • Carbing cooling pannel
  • New battery < 6 months old
I have had the timing belt and water pump done which included a genuine Nissan timing kit including Nissan belt, seals pulleys and water pump, While this was all apart, an OS Giken adjustable cam gear was installed as well as a new OEM thermostat.
The car has approx 160,000km’s on it in total. The car currently has a Nismo dash in it which reads less however, i'm just being honest.
The last service was done by me around 1000km ago which included
  • Engine Oil
  • Spark Plugs
  • Braided Brake Lines
  • Front Brake Pads
  • Thicker alloy radiator
  • New OEM Clutch Fan
  • Flush Coolant
Price as is: $19,500 - Negotiable
Options:
  • BYO Wheels -$1000
  • Rear Spoiler removed -$1000
  • BYO Seats -$500
  • Like 2
https://www.sau.com.au/forums/topic/472903-1998-r34-gtt-manual-coupe/
  • 2 months later...
  • 1 month later...
Bump.
Since the ad was posted I've since:
- Replaced all coolant/heater lines in the car
- Replaced all fluids
- New Oil/Air and Fuel filters
- New PCV valve and hose
- New rocker cover gaskets
- Hankook Ventus RS4 Tyres all round
- 12 Months Rego
Cheers :)
  • 4 months later...
Bump,
Moving overseas for work, grab yourself a bargain :( Have also added the following since last update.
- Greddy Oil Cooler
Replaced all fluids
- New Thermostat & Radiator Hoses (nissan)
- Nismo Engine Mounts
- Nismo Gearbox Mounts
- 098 GTT plates in Jap Style
I am also going to advertise this on carsales.
As it stands  $17,500 w/ wing, wheels, stock seats etc etc will also throw in spares that I have. Happy to negotiate if you actually come and see the car.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
