Hi guys having major problems with the brakes on my r33 skyline gtst non abs.
There is no leaks at the calipers, master cylinder or anywhere on the brake lines everything is solid.
With the engine off you pump the brakes 3 times they sit high and hard with no pressure drop if you apply consistent pressure (Master Cylinder is 100%)
Once you turn the engine on, the brake pedal drops to half travel if you put a bit of pressure on it and the braking doesnt feel the best. I cannot for the life of me think what is wrong, I have swapped out the master cylinder and brake booster from my friends 33 which has great pedal feel. Has been properly bled 3 times there is literally no bubbles in the system at all.
Manual bleed, vacuum bleed, reverse pressure bled.
Bought 2 metres of clear line and made sure there was no bubbles it is definitely bled right it is driving me crazy.
Thank you.
https://www.sau.com.au/forums/topic/472911-brake-problems-r33-gtst-non-abs/
1 hour ago, Dobz said:
So it’s high and hard before you turn her on, once she’s turned on it drops half way and softens up?
Serious now, have you played around with the pedal adjustment?
#Brazzers
No haven't played with the pedal adjustment, comparing it to my friends measuring the length of the thread thru the nut on the brake pedal assembly mine sticks out 5.2mm and his is 5.1mm with a bit of error in measurement due to the difficulty of getting the vernier in there it is the same.
If you think it will fix it might give it a shot tonight look up a tutorial now.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
