Guys
I've decided to entertain the idea of parting with my project car of nearly 13 years.
Over the past 13 years I've been through many stages in my life and career and therefore the car has sat idle needing the love of an individual that I can no longer provide.
Basically up for EOI is a HCR32 with a 2.4ltr stroked rb20det.
Engine:
- Rb20det platform
- RB26 crank
- Forged H-beam rods
- 84mm wiseco forged pistons
- ACL bearings
- Half grouted block
- ATI balancer
- Crank trigger kit
- Top mount gt3582r setup
- Custom hypertune intake with 90mm throttle body
- Sard 650cc injectors
- Sard RB26 fuel rail
- HKS cam gears
- Tomei 272 9.25 cams in+ex
- Ported and polished head
- ARP head studs
- Tomei 1mm 84mm head gasket
- Spitfire coil packs
Body & driveline:
- Custom black 2 pack respray with factory body kit
- 18" wheels all around 265 rear 235 front
- Single piece tail shaft
- cut and shut RB26 gearbox
- hsd coilovers
- koyorad 52mm radiator
- hicas removal bar
Electronics & Other
- Haltech ps2000 ecu
- iq3 dash
- dual external Bosch fuel pumps with surge tank
- dry cell battery relocated to the boot
Basically everything I could do has been done and just needing the base timing completed and run in tune.
I'm putting $15,000 on it EOI take it as it is.
Making this post is something I've been thinking of since my son was born last year hoping I would have the time to finish the car since the engineer build was completed mid 2016.
Please no haters it is what it is.
Thanks
https://www.sau.com.au/forums/topic/472938-1990-r32-gts-t-eoi/
  • 1 month later...
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
