Hi guys,
I decided to start my build thread here at SAU.com.au as mentioned in my introduction thread a few weeks ago.
The car was imported from Japan in 2014. Completely OEM (RB25DET NEO, AT, Sedan, KR4, built in 1998, 50220km). No modifications were made, which was very important for me. A few scratches and small dents here and there... nothing special.
Due to the standards for registration here in Germany several things had to be done. This includes new lenses with an e-number (certified registration within the EU) for the headlights, a rear fog-lamp and new tires with an e-number, too. After that the car was ready for German streets.
In 2015 I bought a new Blitz Nur Spec RX as a replacement for the factory one and Nismo indicators.
It was a little strange to me that all the stickers (timing belt change, oil change, ...) were removed. And now comes the very - and with very I really mean fu**ing very very very very - bad thing about the car... The odometer reading was manipulated. During the change of the air purifier I've found a small sticker in the glovebox which says "Filter change at 86.xxx km" and a Japanese date (April/May 2009). Via the page japaneseodometercheck.com I figured out the correct odometer reading, which was around 100.218km at the time I bought the car. After that I decided to check the compression ratio of the engine. Well... guess what? Yes! They were not as good as expected.
In this moment I thought "God damn it! Let's drive the car intil the engine doesn't work anymore. Fu** off!". To my astonishment the engine survived 2015 and 2016. During the off season (October 2015 until April 2016) the transmission was swapped from AT to MT with parts of an wrecked ER34. I've done this by myself because I wanted to widen my skills and knowledge.
(That buddy really grew me some grey hair :D)
From March 2017 until August 2017 the engine was completely overhauled. Due to that process some aftermarket parts were fitted as well. ;)
The car now looks like this:
21587186_1491875224213038_3463246758906226593_o.thumb.jpg.0bded62023c4a7284f193756fb3692cd.jpg
Let's see what will happen to it in 2018. A few parts are stored in my garage... :)
If you want me to post my spec list just let me know.
Regards
Michael
Edited by n0va
  • Like 4
https://www.sau.com.au/forums/topic/473032-er34-sedan-by-n0va/
8 hours ago, Jordy32 said:
Cool car mate, welcome to the forum.
What's on the cards for 2018?
Thanks a lot!
The plans are as follows:
  • Blitz SE intercooler kit
  • Blitz RD oil cooler kit
  • Uras ducktail
  • Link G4+
  • GTX3071R
  • R35 injectors
  • Z32 MAF
  • Remap (ROZ 98)
Let's see what can be done in 2018. Hopefully all of it. :)
8 hours ago, GTSBoy said:
Yup, welcome to Jap import life.  To be clear, you should NEVER trust the indicated kms on the odo on any import.  Everybody here has known about it for 20+ years.  It's a fact of life.
Well... I was young and stupid. :D It should be obviously that not every sold JDM car has done ~100.000km after all those years. I've learned my lesson. Believe me.
  • 7 months later...
On 1/4/2018 at 9:27 PM, n0va said:
Thanks a lot!
  • Uras ducktail
  • Link G4+
  • GTX3071R
  • R35 injectors
  • Z32 MAF
  • Remap (ROZ 98)
Nice looking 4 door! What is remap (ROZ 98)? Ok looked it up you mean tune for 98 fuel. Have you got a good tuner lined up?
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
