Hi guys,
I decided to start my build thread here at SAU.com.au as mentioned in my introduction thread a few weeks ago.
The car was imported from Japan in 2014. Completely OEM (RB25DET NEO, AT, Sedan, KR4, built in 1998, 50220km). No modifications were made, which was very important for me. A few scratches and small dents here and there... nothing special.
Due to the standards for registration here in Germany several things had to be done. This includes new lenses with an e-number (certified registration within the EU) for the headlights, a rear fog-lamp and new tires with an e-number, too. After that the car was ready for German streets.
In 2015 I bought a new Blitz Nur Spec RX as a replacement for the factory one and Nismo indicators.
It was a little strange to me that all the stickers (timing belt change, oil change, ...) were removed. And now comes the very - and with very I really mean fu**ing very very very very - bad thing about the car... The odometer reading was manipulated. During the change of the air purifier I've found a small sticker in the glovebox which says "Filter change at 86.xxx km" and a Japanese date (April/May 2009). Via the page japaneseodometercheck.com I figured out the correct odometer reading, which was around 100.218km at the time I bought the car. After that I decided to check the compression ratio of the engine. Well... guess what? Yes! They were not as good as expected.
In this moment I thought "God damn it! Let's drive the car intil the engine doesn't work anymore. Fu** off!". To my astonishment the engine survived 2015 and 2016. During the off season (October 2015 until April 2016) the transmission was swapped from AT to MT with parts of an wrecked ER34. I've done this by myself because I wanted to widen my skills and knowledge.
(That buddy really grew me some grey hair :D)
From March 2017 until August 2017 the engine was completely overhauled. Due to that process some aftermarket parts were fitted as well. ;)
The car now looks like this:
21587186_1491875224213038_3463246758906226593_o.thumb.jpg.0bded62023c4a7284f193756fb3692cd.jpg
Let's see what will happen to it in 2018. A few parts are stored in my garage... :)
If you want me to post my spec list just let me know.
Regards
Michael
Edited by n0va
  • Like 4
https://www.sau.com.au/forums/topic/473032-er34-sedan-by-n0va/
8 hours ago, Jordy32 said:
Cool car mate, welcome to the forum.
What's on the cards for 2018?
Thanks a lot!
The plans are as follows:
  • Blitz SE intercooler kit
  • Blitz RD oil cooler kit
  • Uras ducktail
  • Link G4+
  • GTX3071R
  • R35 injectors
  • Z32 MAF
  • Remap (ROZ 98)
Let's see what can be done in 2018. Hopefully all of it. :)
8 hours ago, GTSBoy said:
Yup, welcome to Jap import life.  To be clear, you should NEVER trust the indicated kms on the odo on any import.  Everybody here has known about it for 20+ years.  It's a fact of life.
Well... I was young and stupid. :D It should be obviously that not every sold JDM car has done ~100.000km after all those years. I've learned my lesson. Believe me.
  • 7 months later...
On 1/4/2018 at 9:27 PM, n0va said:
Thanks a lot!
  • Uras ducktail
  • Link G4+
  • GTX3071R
  • R35 injectors
  • Z32 MAF
  • Remap (ROZ 98)
Nice looking 4 door! What is remap (ROZ 98)? Ok looked it up you mean tune for 98 fuel. Have you got a good tuner lined up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
