The ECUTEK has RACEROM, the rev match is enabled (I am really bad at heel toe) this does it for you.
Also has flat foot shifting enabled ( ECUTEK uses both fuel cut and ignition retard working together), if it was just fuel cut I wouldnt use it, I like my pistons, if it was just ignition I wouldn't use it as I like my turbo.
It has launch control, but this feature has never been enabled.
I may be interested in a mint original AUD S15 with cash my way.
Minor mods are good but......
Disclaimer: No pi gs, no respays, no 400hp fully dayglow spec with body kits, no prior accident repairs.
I will have it checked out with a fine tooth comb.
I have been looking around lately at S15's, I want a good one though, and by good I mean mint, the better the car the less cash my way.
Example: I missed out one 2 years ago, it had 4k original km on it and it sold for 28k.
Both cars will end up at a local shop for inspection, Pulse Racing is close to me.
  • 3 weeks later...
On 5/14/2018 at 2:25 PM, The Panda said:
If you are looking for a p-plater fun weekend car - I have an AP1 S2000... 4.44 diff and some other fun stuff. I need a more work appropriate car :(
Shoot me a email with some more info and pics mate. How much do you think the S2000 is worth realistically.
Thanks for the email
Your car looks sweet but sadly not what I am after.
I wish you luck with your sale.
Cheers
  • 4 weeks later...
Keen to hear your thoughts on the 86, coming from the STI, by the looks you got the limited ed. ver with the brembos, sachs and updated diff?
Really liking these at the moment, just finding it hard to find $30K from the back of the sofa.
So far so good, I replaced the Michelins with some RS4's today, should be good once they are scrubbed in, I had some RS3's on my MX5 and liked them alot.
In the couple of days I've had it I'm loving it, even with the crappy Michelins it was a hoot, it's good to be back in a light(ish) RWD platform.
Power wise it wouldn't pull the skin of custard, but that not the point of it, or why I got it.
Wringing its neck, throwing it into a corner, playing with some oversteer is so much fun.
I also grabbed a cat back for it, a XForce 2.5" jobbie, sounds alot better, well you can hear it now anyway, with the stock cat back I couldn't even hear the exhaust, I estimate the power increase from the cat back is an astonishing 0%.
So, for future mods, some alignment bolts from whiteline are on the cards, stock camber adjustments are non existent, apart from toe, stock camber is 0.0 deg, I'm going to hammer some corners and see what the tyres are saying and dial some in from there.
Cheers
  • Like 1
On 7/3/2018 at 9:31 AM, JGTC said:
Awesome, good to hear Mark, i totally agree with you on that simple layout is best as i get older, more fun at less speed with less to go wrong.
Camber bolts only gave me -0.5 with them maxed out, rears are -1.3 L and 0.97 R (not adjustable).
I'll try some 14mm lower camber bolts for the front and see where that puts it, if all else fails I will grab some strut tops as well, I will grab some adjustable arms for the rear.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
