Hi All,
Thought I would share my GTR as I get sent a lot of PM's with questions etc. happy to help anyone out, I'm new to GTR scene but not RB's having owned some big power RB30 VL's in my life, rwally enjoying the change but the do hurt the back pocket lol!
Lot people will probably know this GTR plates " HANIBL " has been on the Motive DVD GTR vids etc, was originally built by Team Karam with a straight 26 setup and then the owner went all out which when I was lucky enough to scoop it up when he sold it on a spare of the moment decision just after it was put back on the road with the new setup.
Quick run down on the car:
1992 GTR fully resprayed in original silver by 2SUS
RD diesel block, half grout, Nitto 3.2 stroker kit, full CNC 26 head with head sealing rings, billet plazmaman 12 injector inlet, 6 boost manifold with precision 8285 ( recent addition bought it with a 7675 ) 290 kelford cams, Elite 2000 ecu, mechanical fuel pump, external wet sump oil pump, Al's Raceglides AWD turbo 400, Quaife front diff, billet axles, full IHRA spec chromoly cage list goes on.
Car made 1183hp @ 45psi as a manual, car is currently being tuned by Ben D"Annello in Melbourne after some updates, we found the old cooler was no good so since upgraded to a plazmaman pro series 100mm cooler with immediate results, now just upgraded some wiring etc. and hoping to finish off the tune in the coming weeks, currently on 38psi has made 1050hp or 778rwkw thru the auto but some trigger miss count issues have held us back from turning it up or adding the timing it wants hence the wiring upgrades.
My aim for the car is just to run an 8 sec pass, everyone will say it will do it easy but I have had the cars in the past to do it and one way or another it just hasn't come together, so fingers crossed it will come together this time around, the car has no expense spared on it, I'm very fussy so plenty left to do but that's the enjoyment of owning a car.
Quick video and pics attached hope you enjoy.
HANIBL 38psi 8285.MOV
  • Like 10
https://www.sau.com.au/forums/topic/473365-hanibl-r32-gtr/
Finally got the car back on the dyno after fitting a new Haltech engine loom and trigger sensors.
No more miss counts, car ran perfect and was doing back to back 1100hp pulls thru the TH400 on just over 40 psi, we were being conservative given given all the small dramas we have had, left it quite rich and it has no boost control left so more wastegate springs needed if we want to lean on it a bit more.
Now to hit the track and back up the numbers.
HANIBL 42psi.MOV
  • Like 4
https://www.sau.com.au/forums/topic/473365-hanibl-r32-gtr/#findComment-7869411
  • 9 months later...
On ‎12‎/‎14‎/‎2018 at 6:25 PM, Taha said:
Hi any updates  and how much  power did 7675 make
Its actually got the 8285 on it, use to have the 7675 which is made 1170hp at the wheels when it was manual and 1000hp when it was auto.
https://www.sau.com.au/forums/topic/473365-hanibl-r32-gtr/#findComment-7894098
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
