Does stock cover really fit without modification?
going by how high they look at where my yaris coils sit I couldn't see it fitting without having to trim the ignitor depression like you do with yaris coils?
the platinum kit is good but does have a draw back the coils dont pull back through the billet plate (3d printed boosts are too big). Minor gripe, ive had about 5 kits through with zero issues.
Had a golebys yaris coil die at the track afew weeks ago, Im glad ive found this thread and tbh im alittle pissed they are not genuine but not surprised given the quality of some of the parts supplied ie "precision v band kit" not genuine either... I will replace all 6 with genuine items double check the dwell and hopefully they should last alot longer then 500kms
Are you able to expand on the precision v band kit?
Clamp gauled up and fell apart before we had finished fabbing exhaust.. afew friends of mine over here have had the same issue and one was even able to compare to a genuine kit he purchased a year or two prior, looks like its was just a generic china "suits 3" PT" kit I ended up using a 2 - 3/4" tial clamp..
I dont want to drag them down as ive had afew other parts from them and they have been fine..
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
