Hi, Ive had my GTR for a long time now. Its stock apart from a catback exhaust and high flow cat. It came with a boost controller set to 1bar and had an Impul remap ecu.
The first thing i did was install power fc and newer model hks evc tuned to stock boost for australian 98 vpower.
My main question is since I like the car in standard form and dont drive it except in my estate to keep it running once a week. Would the stock ecu be a better option with the factory tune and safety features?
Are there any options for a remap? Or should i stick to the power fc and if i do, would it be wise to do a tune and dyno run since its been unchanged for over 5 years.
Any advice would be appreciated.
-John
https://www.sau.com.au/forums/topic/473572-bnr34-oem-ecu-or-power-fc/
5 hours ago, KiwiRS4T said:
If you know a good tuner who knows PFC just get a safe tune. The Impul ecu was tuned in Japan for Japanese fuel - your PFC can be tuned to match the fuel you are buying .
1 hour ago, r32-25t said:
Leave it alone cause with your current power fc the car is tuned for the fuel it is using, Nissan tune these to suit the high octane Japanese fuel and engines tend to die over here because of it
Yes i did install the fc as soon as i got the car. I used octane booster and drove gently to be safe while i waited for the date of the tune.
I asked the tuner to run the car safe and i always watch the knock.
Main thing id like to know is will the power fc current tune (since it was performed over 5 years ago) be optimal after years and maybe 6k kms?
And if i put a stock ecu in, how good were they; can they run optimally for the small modifications like an aftermarket exhaust and the subsequent mild increase in boost. Things like knock retard and closed loop?
Thanks for the replies so far!
There is no reason for the car to be retuned unless you where never happy with the tune done.
I wouldn't go back to a stock untuned ecu. For what you're doing with your car, the power fc is sufficient and although they dont have many of the modern ecu features, they do their job of running an rb very well. Cheers.
The power fc will be fine even after this time, the stock ecu will generally cause detonation even at mild modification level in Australia
Thanks guys, the power fc while older gen is still popular and seems to do the job fine. I just wanted to clarify about the oem ecu.
Seeing modern cars have flash tunes on the factory ecu: from the r35 to even a falcon xr6 turbo; i was curious if any company flash the older gen bnr series ecu with good results. Ive heard of nistune.
OK, let's be clear.  The Nissan ECUs of that era are (almost all) EEPROM based, so you can burn new EEPROMs and jam them in there.  But these days we just install a Nistune daughterboard which makes the ECU fully programmable.  Originally this was about as good as PowerFC + a little bit.  These days Nistune is much better even than that.
But you still don't need to be doing even that.
not on a r34 GTR ecu, no nistune support. i have a few jap ones here that are but its a big job and a pfc is cheaper as a tuned job.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
