So just done ffp on my neo (greddy style) along with the fuel rail so I bought a sard fpr it’s a knock off. Trying to set it a at 43psi without vacuum but it won’t raise or lower fuel pressure. It’s static at about 39psi ? I have it setup like so :
tank>filter>fuel rail>fpr>return to tank.
Anything i have missed or is it just a bad fpr? I know it’s a knockoff but it’s new and it should work?
Edited by r34.rory
Added pic
https://www.sau.com.au/forums/topic/473746-can%E2%80%99t-get-fpr-to-adjust/
What fuel pump do you have?
What size is the return line?
Is there any kinks in the return line?
What size is the outlet of the reg?
Knock off regs is just asking for trouble. It’s kind of important.
On 12/04/2018 at 12:19 PM, inmaniac said:
Shouldn't use a knock-off for something so important, such as an item related to fuel delivery.
Trust me.. I only speak from experience
Lol true.. I still have one fuel damper if that would even matter? the damper is about 3/4 inch after the return port on the fpr.
new fpr still not arrived so I went to have a look again.
11 hours ago, NEO25T said:
You havent got fuel going in the out port of the reg? Not sure if it would make a difference or not
Nah the outport is returning to tank. also tried another fpr and gauge and still can’t adjust either way !! wtf I’m f**king annoyed to say the least....
5 hours ago, KiwiRS4T said:
Replace the pump since you have one and eliminate that as a problem. If your new fpr still doesn't show 43 psi get an adapter for your stocker and use that.
yeah I think I will swap the pump out. if no success I will get the stock fpr and try a gauge on it.
Car was running fine before I changed the plenum. It’s sat for a couple months whilst doing so maybe the battery is weak I’ll check to voltage for the battery and the pump. What should the pump be getting do you know ?
Edited by r34.rory
7 hours ago, r34.rory said:
It adjusts down and needle doesn’t fluctuate. Gets to 3 bar and doesn’t get any higher and fluctuates. what’s a good brand fpr? Malpassi any good?
Nissan
Or if you want to spend more money  - Turbosmart or Tomei (but beware - lots of Tomei knock-offs around.
    • Haha that's wholesome as! Looks like we're raising a generation of female rev heads and classic shit box owners 🤣
    • Haha nice, my kids are the same two older boys say cars are boring while younger girls like them. My 1.5yo daughter watches D1GP on YouTube with me, holding a toy plate for steering wheel and making brmm brmm noises
    • Took the car out to see if it still starts, sure does. Daughter wanted to for a spin too, she loves it when it doses, also cries when we come home and try to take her out of the baby seat 🥲  I actually put the seat in for her brother, but he absolutely hates the shitbox. Anyhow, so after looking at real boats, and transoms, bait tanks etc. and scupper valves attached to them, I came up with ideas to improve the catch can. The primary goal was to stop the interior smelling like vented catch can shit when the windows are down OR when the HVAC is not recirculated. My catch can has a sump drain/feed at the bottom, 2x cam cover inlets, 1x outlet back to the intake pipe and 1x vent at the top. The initial theory was at idle, and off boost there would be just enough suction from the intake pipe (pre turbo) to pull back any smelly shit from the catch can before it could escape out of the vent (which does have 1x layer of foam and a fine mesh screen on top). It kind of works, however on hot days, the motor is breathing more than the suction provided from the intake pipe (pre turbo) and there's a bit of vapours escaping (not a bit amount, but enough to piss me off). I could have just sealed off the vent, however it would mean each time I take it to the track or decide to drive it with a bit of enthusiasm, I would need to remove the seal. To address this, using scupper valve idea, I used a 3mm sheet of rubber and cut essentially a valve that requires a bit of pressure to crack open and vent. Took the shit box for a drive today, came back and parked the car. No heavy stench, great success ☺️ I still would swap for a F80 LCI or W204 2012+ C63 AMG, if anyone is keen 😅
    • I'm with Kinkstaah on this one. Do it once, do it right. So much better for your mental health. The sneaky thing about the fuel pump wiring is that it will work perfectly fine for the longest time. Until that one moment when it decides to shit the bed. And it's not worth the paranoia from not trusting the car anymore. At least other mechanical issues announce themselves by developing some noise or other warning. If you have the funds, I'd suggest to go with a good kit like Frenchys and get the work done by a trustworthy shop. No regrets there. The only downside to the Frenchys kit on the Stagea/R32 GTR is that their fuel level sender is not on point. But looks like the R33 kit maintains the factory sender so should not be an issue. This is what the botched setup on my Stagea looked like before it stopped working. It had melted its way quite a distance down. Glad it didn't burn down the car.   Some links I came across when I looked for solutions: Radium sells a DIY wiring kit that looks promising. I didn't buy it though, I let my workshop decide on wiring. https://www.prospeedracing.com.au/products/radium-diy-fuel-pump-hard-wiring-kit-17-0031 https://www.radiumauto.com/DIY-Fuel-Pump-Wiring-Kit-P368.aspx   You can also get cheap replacements for the locking ring depending on how mangled it looks: https://www.kudosmotorsports.com/Nissan-17343-79900-Fuel-Tank-Outlet-Locking-Ring-for-Nissan-S14-S15-BNR32-R33-R34-AWC34 There are tools for unscrewing it as well so you don't have to abuse it with a screwdriver and mallet. The Frenchys one is expensive but I'm sure there are cheaper ones.
