So just done ffp on my neo (greddy style) along with the fuel rail so I bought a sard fpr it’s a knock off. Trying to set it a at 43psi without vacuum but it won’t raise or lower fuel pressure. It’s static at about 39psi ? I have it setup like so :
tank>filter>fuel rail>fpr>return to tank.
Anything i have missed or is it just a bad fpr? I know it’s a knockoff but it’s new and it should work?
Edited by r34.rory
Added pic
https://www.sau.com.au/forums/topic/473746-can%E2%80%99t-get-fpr-to-adjust/
What fuel pump do you have?
What size is the return line?
Is there any kinks in the return line?
What size is the outlet of the reg?
Knock off regs is just asking for trouble. It’s kind of important.
On 12/04/2018 at 12:19 PM, inmaniac said:
Shouldn't use a knock-off for something so important, such as an item related to fuel delivery.
Trust me.. I only speak from experience
Lol true.. I still have one fuel damper if that would even matter? the damper is about 3/4 inch after the return port on the fpr.
new fpr still not arrived so I went to have a look again.
11 hours ago, NEO25T said:
You havent got fuel going in the out port of the reg? Not sure if it would make a difference or not
Nah the outport is returning to tank. also tried another fpr and gauge and still can’t adjust either way !! wtf I’m f**king annoyed to say the least....
5 hours ago, KiwiRS4T said:
Replace the pump since you have one and eliminate that as a problem. If your new fpr still doesn't show 43 psi get an adapter for your stocker and use that.
yeah I think I will swap the pump out. if no success I will get the stock fpr and try a gauge on it.
Car was running fine before I changed the plenum. It’s sat for a couple months whilst doing so maybe the battery is weak I’ll check to voltage for the battery and the pump. What should the pump be getting do you know ?
Edited by r34.rory
7 hours ago, r34.rory said:
It adjusts down and needle doesn’t fluctuate. Gets to 3 bar and doesn’t get any higher and fluctuates. what’s a good brand fpr? Malpassi any good?
Nissan
Or if you want to spend more money  - Turbosmart or Tomei (but beware - lots of Tomei knock-offs around.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
