So I’m new to this whole r32 thing and I’m sure this topic has been covered ten fold. Hours of research got me nowhere. But my situation is slightly different. I have a R32 GTS-t with an r33 rb25det swap. my issue is removing the hicas.. I have the R33 power steering pump that has one pressure line, yet I have that extra pressure line the R32 uses for the hicas pressure line that I’m trying to loop in to the power steering in order to maintain my power steering. I’ve deleted the Hicas pump from the frame rail, looped the cooler line and removed lines running all the way to the back. I’m just trying to now loop the second pressure line Into the power steering system.  Would it be easier just to find the RB20 Gtst power steering pump with two pressure line fittings or is there something I’m missing and it’s a simple fix?
as stated, super new to this please help!!!
Um.  What?
The HICAS pressure line is completely separate from the power steering.  When I did exactly what you're doing (but with a Neo), I simply removed everything to do with HICAS (the thing on the frame rail is a pair of solenoid valves, not a pump).  With everything HICAS removed, the power steering pump simply connects to the rack via the original line (adapted at the pump end owing to being a different pump) and the return from the rack goes where it always did.  That's it.
And don't loop the cooler.  Plumb it into the return line.  You need the cooler.
  • Confused 1
I followed a diy about looping the cooler line into the line that was removed from the hicas “solenoid” as you said.. following THAT line, it eventually ends at the second pressure line by the pump which I believed to have been for the hicas. Which again I don’t have a 2 line pump it’s a single line pump which I have connected to the other pressure line that goes to the rack. My issue is the line the diy says to connect to the cooler line only runs to the open pressure line I have no hole for.
For example. In the second picture below, The red dots are the line I’m talking about, the blue is what I tried to loop but tracing the red lines back from where I tried to loop it in it came to that second pressure line which I don’t have connected because my pump is a non hicas pump, it only has the one banjo for the one pressure line, as shown below in the first picture to the left.
Edited by Dhoward24
It's not rocket surgery.  Work it out yourself.  The PS circuit is dead simple.  There are 3-4 things in it (depending whether you put the cooler into the return or not).  Just hook them up.  Following a DIY that does not work for your gear is a fool's errand.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
