I have a whole car with a mint engine no knocks perfect compression new turbo for only $2600 if your interested. 0421 605 491. Unregistered but you don't need a tow truck could get an unregistered permit for up to 3 days and drive it anywhere in Australia.
Edited by opalbrown
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
