Hi guys just wanted to ask for your advise about the fitment of this crank collar.
The grub screws are drilled about 3mm into the crank, i have taken them out and not screwed them back in all the way.
My concern is it looks like the crank has been machined so the collar will slip on and loctite used to help hold it.
I hope im wrong but what are your thoughts, would you be happy to use as is, if not what are my options.
Thanks ?
Screenshot_20180424-085059_Gallery_resized_1.thumb.jpg.79d104de72293c6479712f2862b110ba.jpgScreenshot_20180424-085029_Gallery_resized_1.thumb.jpg.08c1d599654b1f4a1c98e59ccfe979ba.jpgScreenshot_20180424-085112_Gallery_resized_1.thumb.jpg.f1e720028c6649433f847420cd054f5f.jpg
Edited by NEO25T
Spelling
https://www.sau.com.au/forums/topic/473854-crank-collar-fitment/
They were like figjam do you know how many engines we do here, really poor attitude when i asked them about.
Said they would not have sent it out if that was the case but the owner didnt see it before i picked up.
Tone changed a little when i said it had red loctite and they wanted me to bring it back for them to inspect, but things got a little heated and i said i wouldnt let them touch it.
It's tricky to say for sure. They may have gone above and beyond and used the loctite even though it wasnt required. Or they realised it slipped on and loctited it.
Loctite is pretty good stuff, but for such an important part of the engine I wouldn't want any doubts .
Definitely sucks to not know for sure
  • Like 1
Im thinking lightly warm with heat gun and give it a twist to see if it moves.
On the other hand the loctite and grubscrews should hold it?
Possibility to have it welded maybe, im just not sure.
Hi octane posted a pic on facebook where a crank nose had snapped off, so ive got it on my head this is going to do the same lol.
Its dangerous when you have a little bit of information......
Its meant to be a shrink fit.  No loctite. If the grubscrews have been screwed into the crank you can be sure the collar has been fitted improperly. The  fix is to build up the crank with weld and machine it down to the correct size to achieve a shrink fit.
  • Like 1
Should be taken back to hear what they have to say about it. How many people work there, is there a chance someone dodgy in the workshop did the job?
The proper course of action is to have the collar taken off and sizes checked, you also want to see if they put a decent radius in the corner. Too small of a radius could lead to snappage.
3 hours ago, Ben C34 said:
, wouldn't it make more sense to just get a new crank collar made and achieve The Shrink fit with the new collar rather than welding and grinding a crank which would certainly cost heaps more?
Not if you can make the idiot who made the mistake  rectify it at his expense. Plus the holes drilled in the nose of the crank should be filled with weld. But failing that I guess you could get a new custom crank collar made but unless you had the means to make it yourself it would not be cheap.
2 hours ago, NEO25T said:
I wonder if different manufacturers collars are slightly different sizes.
Not a precise measurement but the crank measures 35mm where the collar slides on
The crank collars I used to sell are made in large quantities on  CNC equipment and do not vary at all or from Tomei or other collars. It is obvious that the person who turned down the crank made a mistake or just did not know what a shrink fit is... in this case the crank needs to be left 0.05 to 0.1mm larger in diameter than the ID of the collar.
21 hours ago, Dobz said:
So you're just going to give up that easy?
No just need a time out lol, im use to things not working out the first attempt or 2.
This car really should have been deregistered and sent to scrap but i kind of liked it so gave it a home, its been an interesting/ expensive 12 months of ownership......
Typical Skyline ownership, when my motor exploded I was going to strap and strip the car.
Somehow, a few cans later a few drunken discussions with people I ended up spending triple the car's worth and now have a built motor and a barely working car LOL.
  • Like 1
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
