Hey guys,
Just found an issue today, stuck what to do.
I have the R34 GTT, all has been fine and so on for ages... Not driven car since last weekend.
Went out today, just found out the Brake Lights don't work....
I can turn on the lights as normal, but when I press Brake pedal, whether in ' no lights', 'side lights' or full lights' mode, I get no Brake Lights frown.giffrown.gif
I changed the 10A Red fuse from the Fuse box in the engine Bay, which is labelled as 'TAIL' which is between 'TCS' and 'HORN' , but still no lights, and not sure the 'TAIL' fuse relates to brake lights...
The fuse panel down by the pedals = in Jap (so cant read which fuse is for what!)  Not even sure its a fuse problem.
Not sure what to check, or where, etc. Any help, i would be very grateful smile.gif
https://www.sau.com.au/forums/topic/473901-no-brake-lights-on-r34-gtt/
Since posting this message, had a few peeps say looking for the 'blue' brake switch at the top of the pedal to see if anything come loose.....
Its tight, nothing loose, etc
I did read that the Brake Switch's do fail, but could be either Brake Switch or the Fuse which has popped..  The fuse which is in the panel by the accelerator pedal....
However, the fuse panel cover has all the fuse names in Japanese!  Cant read which fuse is for the Brake Switch Sender....
Google translate can help you with the translation.
Pull the brake light switch plug off and find a bit of wire to bridge it. If the lights don't come on then it could be the fuse or a broken wire somewhere.
If you aren't good with electrics and you can't easily find the problem an auto elec is the easiest way to get it sorted.
Update:
Still not sorted, but had a guy take a look at things, he did his stuff with the Multimeter, checked this, checked that...
Tested the brake switch, swapped the brake switch out, changed fuses....
He tested the points with the meter in the driver side boot area, said no voltage was coming through the wire that powers the 'stop lights'........
So potentially, there is a break in the wire inside the loom that runs from the fuse panel in the footwell......
Question is, where do I go from here ?  find a good Auto sparky ?   is there a bodge that could be done for now, like getting some wire (car speaker wire ???) and running straight from the fuse panel to the relay block (if there is one in the boot) ?
I got a temporary fix in place....
I don't fully understand the fix, but a mate who is an electrician, done a:
Bypass from Brake Switch to Fuse Panel, and temporary ran the wire into the ABS fuse point.......
Quick fix is, I have brake lights, but it shows that there is a break between fuse panel and brake switch.....
Next call is to the Auto electrician guy ! :)
Edited by StuartUK
Typo
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
