First R34 with Carbon ceramic disc?
$10k worth of discs?  Where's the value?  I'm assuming that they will be going back onto the Audi and not actually being used on the track, right?  You do realise that all the Audi/Merc/Porsche owners with ceramic brakes take them off for track work, or even for street work, then put them back on to sell the car with?
  • Haha 1
thumbs up to GToFuS-T. being first worth every cents.
besides we work with AutoRacing Technik. we get our pads custom made, not going to get ripped from euro car makers.
  • Thanks 1
1 hour ago, niZmO_Man said:
Got some spare rotors? Price of those?
got a set of 355 rotors with 4 pots genuine ferrari brakes with adapter available. if interested. for skylines and silvias. M12 bolts. but in steel tho.
$2k for the whole setup.
Edited by godsmind
A gentleman with an incredible NISMO spec build fitted some to his car approx March 2016, I don't want to steal his thunder but it is here (along with the rest of the build - definitely not works safe, incredible car!).
Interested to know your thoughts regarding performance, etc. I don't believe ALL cars that have them stock take them off!
Thanks for the info. Being first in Aus isnt too bad either..i guess:D
Nice nismo built for sure. With performance, it certainly alot lighter than steel discs. yet to find out what is is like and temp range with the custom pads. Not sure if ALLLL cars take them off buddy, certainly the people i know have them on all the time.
Edited by godsmind
Just went through the previous photos. i believe the discs they used are too big, the 35gtr caliper are too small for the disc. the pistons arent really pushing to the center of the pad/disc. Unless i am looking it wrongly?? here with pics of the two setup vs stock. can see there is a big gap between the edge of the caliper and the center hub. As well as the excess material of the pad. guess the pads will be pushed in in an angle causing uneven wear and poor braking performance. Everyone's thought?
0001413_nissan_r35_alcon_racing_380mm_rear_discs.jpeg.67a58222902e124d91606193b976b03c.jpeg5af386709b4a6_canadacarbondisc.jpg.d5b95af58ae480975fe080870934dd79.jpg5af386718e07e_nismobuilt.jpg.949b21f7519b105dd7aae219a6680a94.jpg
Fitment of caliper and pads on the rotors doesn't look right.
That's what happens when they're not really fitted - just sat for e-fame photo op.
 Share
    • Me too. Apparently the new version of Invision will allow some customisation so look forward to a 'Love' reaction and a new 'Like' icon.
    • Which injectors are you using? It's likely the fuelling is off also, so as above.
    • Awesome to know. I have a Series 1, and When pulling my front bumper off for the first time i realised my reo/crash bar was a bit worse for wear, and was going to try pick up a better one soon just so i can replace it. Someone is selling a full series 2 front bar and brackets for a decent price, so was going to probably reuse my brackets and install the new second hand reo/crash bar. I also have a genuine Altia body kit to do up, spray and put on, and not sure if that will use the series 1 or series 2 brackets for the front bumper, so having both will be handy, and knowing i can drill holes out to make stuff fit between series is also handy to know!
    • I should also say that the while they are different the only parts that matter are the center headlight supports and center bar from S1 to S2. The center bar will work, but the S1 has holes that clips go through into the S1 bumper. So if you were super cheap you could simply drill the S2 bar. Same thing with the side/wings. They have slightly different 'clips' but can be made to work. The center headlight brackets however, cannot. This is also where the GTR differs, which has a different center bar, and different headlight supports (to either GTT system), it also has different 'wing' headlight supports which is what I am calling under the headlight. However those CAN be made to work with the GTT Reo for a GTR front bar by a small spacer and a drill/tapping a thread into the reo because the bolt positions are slightly different. So people only really need the center brackets to go between GTT S1, GTT S2, and GTR if you are happy to do some tinkering.
    • Indeed  😃  Appears the site is back up now (migrated not updated) - kudos @funkymonkey & @PranK
