hey there guys
have been a long time reader but first time posting
i have recently had my 96 S2 R33 with RB25DET at the tuner after a bunch of new mods
he was having an issue with the car hesitating for a second or 2 when the throttle is jabbed quickly.. making it feel quite un responsive and laggy ( throttle is fine otherwise, just has to be increased slowly.. its most noticable down low or when giving it a quick rev in neutral)
he believed it to be a TPS issue so i got a new NISSAN TPS the same as what i had in the car. which surprisingly was a S1 TPS (obviously with a S1 Throttle body too, installed by previous owner) with the extra plug and fly lead hanging off it.... he managed to tune it ok but it still has the same issue - just to clarify ive got it plugged into the fly lead plug not the one on the bottom of the sensor.. i believe this is the signal plug
so this is a two pronged question
1. other than the way the the TPS mechanicaly connects to the throttle body are the sensors both the same electronically? 0.5 - 5v DC? - if so it shouldnt matter that i have a S1 sensor on a S2 motor
2. when i tested it i seem to be getting 0.6v at closed throttle and 3v ish at WOT.. i believe its ment to be 0.5 - 5v from what ive read on SAU.. i have hesitated to adjust it as dont want to screw up the tune i have just had... but is this likely to cause the problem i am having.. or is it possible he has compensated for these incorrect voltage readings in the ECU (VIPEC) or something?
any assistance would be greatly appreciated.. and ive been searching for a couple hours and couldnt find anything that answers this completely.. so sorry if this is a repeat post :)
thanks
caleb
Edited by kleb420
If you have a VIPEC you can watch the TPS voltage on your laptop. You can also do a TPS calibration with the VIPEC software. You should be able to see if is seeing the throttle at 0% closed and 100% at Wide open throttle. If this is the case it wont need calibrating
Take it back to your tuner?
Yuh, if it was a factory ECU I would have said TPS adjustment 100%.  Because it's aftermarket ECU, there is nothing stopping you/the tuner from adjusting it either in the ECU or in the engine bay.  In other words, the tuner shouldn't be having any trouble with the new TPS if he set it up as he installed it, like he should have.
ok think ive worked it out. checked it on my laptop and it confirmed the voltages i was reading... range was 1.4% at closed ant 99.8% at WOT... but i dont think that was the problem.. when i loosened the TPS i could move it alot without the ECU getting a change in %... so i believe its because the shaft on my TB is a bit smaller than the inside of the TPS.. bit of foil tape around the shaft and its much better :) also re calibrated the TPS % in the ECU so all is well now.. not 100% but very close
thanks for the imput guys
caleb
Too high or too low fuel pressure can also cause this im addition to the two step voltage the ecu is able to provide the fuel pump. If its a  aftermarket one it wont flow the same as stock on low/high voltage switching.
Thats what it was for me and it had nothing to do with tps
Edited by sonicz
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
