Hey all,
Thought i had a build thread for my 32 but cant see it so maybe not, anyway.
Bought (becuase it was cheapppp) what can only be described as the worst looking r32 around. Ugly kit, check. Ugly white painted interior, check. $2 bucket seat, check. on LPG, yes LPG! check.
i wanted a project, so i bought it for cheap and brought it home
  • Like 1
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/
Since i killed the front bar, i found a GTR front bar and lip
Plus for now also got a standard r32 bonnet
Also removed everything to do with the LPG, thankfully it wasnt dedicated LPG. Just had to remove, fill a few holes here and there and bingo
Edited by Adz2332
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877417
a pair of excellent nic 32 gtr seats came up for cheap so replaced the crappy $2 recliners in it.
Plus started to remove anything painted white inside the car! and also changed the steering wheel to one i had lying around
Edited by Adz2332
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877419
The rb20 still runs fine, so removed to give it a bit of a tidy up and new gaskets etc etc. not looking for this car to be a power house, always wanted something that looks nice when you pop the hood. plus i already have my track car for speed.
So while the engine is out im tiding up the engine bay. removing all the HICAS, Putting the Battery in the boot, and hiding the fuse box. Will also change a couple things like the washer bottle, over flow etc. Will then fill holes, smooth and paint
Edited by Adz2332
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877423
I had a look at the Pandom kit for the 32 and didnt like it... so instead i did a thing.
I bought genuine rocket bunny flares front and back, same as the car below, from streeter.
Now not 100% sure ill go this way but they are sitting there
  • Like 3
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877426
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
