Hey guys I need some help from some fellow members I’m in the next stage of my build and that’s suspension the car is my r32 four door but I need to lay the power down to the rear what suspension is every one running these days ?  Rang just jap talking to them they recomaned bc coils but I am open to options the car will be setup for drag racing the set up now is way to hard
https://www.sau.com.au/forums/topic/474230-r32-4-door-drag-set-up/
First you need to fix the subframe.  The anti-squat geometry on R32s is the enemy of drag traction.
After you've replaced it with an S14 subframe, put a full set of adjustable arms into it and ensure that they are dialled in for minimal camber and as little bump steer as possible.  Then speak to MCA about some custom valved coilovers.
Yuh, but the subframe is essentially the same as the GTSt subframe.  The stuff that's bolted to it is not responsible for the geometry.
And the GTR diff isn't "stronger" than the GTSt diff.  Yeah, sure, it's a mechanical LSD, but then anyone dragging a non GTR is going to put a mech centre into the GTSt diff anyway.  And the 6 bolt axles are only marginally stronger than the 5 bolt.  So, go ahead and put that stuff in if you want to, but don't make the mistake of thinking that it's a major upgrade in terms of strength.  And do not make the mistake of thinking that the GTR subframe is better than the one that you have.
In the R33/4 and S14/5 cars, the suspension geometry was significantly improved over the R32 & S13 era cars.  And the S chassis cars don't have HICAS, which is worth getting rid of for any car, but certainly good to get rid of for drag.
agree with all above
I dont know what power your going to run but I have personally run  high 500's hp with rb25 in both drift and circuit in r32 4 door with all of the above and have never had a problem with axles etc (I know drag is a little different with launches)
then if anything you can spend the same money getting s14 subframe + diif + below upgraded axles for a better outcome than circa $1000 - $1500 on the full rear GTR cradle
http://www.driveshaftshop.com/import-axles/nissan/skyline/nissan-rwd-gt-s-and-variants-rear-axle-bar-upgrade-bars-only
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
