Hi All,
recently fitted a new engine into a shell. I purchased the shell and have never heard a motor run in it so not sure if a wiring issue or what, could be a big fan of worms! ?The motor cranks but won’t start. Not running on any cyl. I have checked for fuel and lines are correct (see pic) Also what should the tomei fpr be set to? Has standard injectors fitted. Is there a way I can bypass the ecu or link to ground the injectors? Also should the apexi ecu have a bracket to be grounded or does it ground through one of the pin outs?
Have turned the ignition on and removed CAS and spun by hand. Can hear the injectors clicking and have spark from all coils. Also it has an apexi power fc fitted so is there a way of testing that this is working? Also so have the afm connected and was reading about 400mV or there abouts.
Not sure if it’s an immobiliser related issue either, pulling my hair out just trying to get this motor to start! Any help is much appreciated!
First is current one on car which was from the running motor (previous)
Second pic is from the current motor I’ve fitted but I removed it because it was a bit tight the bearing and when you spin it by hand it’s a little notchy.
This is what the fpr is doing. Could this be the issue?
Also what is the regulator that’s connected to the return line of the fuel under the brake booster? I don’t have one fitted.
Sorry about lines being a mess
Is it running the same AFM as the last car the Power FC was fitted to? Same injectors?
Have you had a read of PaulR33's Power Fc FAQ?
Im betting if you have fuel and spark then its probably a setting not quite right
Are you getting spark to the spark plugs? Perhaps do the old screw driver into coil and cam cover trick.
When you turn the CAS or crank the car it should spark.
Also take out your spark plugs and see if they're all fouled and cooked.
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
