So, I've recently purchased a C34 Stagea with the legendary RB25DET engine. It was brought to my attention that I cant drive a turbocharged car on my green P's. I was un-aware of this because im from NZ and there were no restrictions on engine size there so it never crossed my mind. I'm also on green p's only because I am under 20 I transfered my New Zealand full licence and have my green P's until I'm twenty in January. So anyway I came to discover that I can get an exemption since it's power to weight ratio is under the limit. I went onto the raws website and screenshotted and printed off the details of the car, weight and engine power output. took it into the department of transport and they said they couldn't use it and that I need a letter from nissan stating the weight and power output. I emailed nissan Australia and Nissan Japan and they both said they couldn't help thats when i found the raws website but apparently that's un-usable, completely wasted my time waiting at the department of transport for nothing which is always fun... If anyone could help it would be greatly appreciated! Dont wanna go selling it straight after buying it. Thanks!
Yeah good luck getting such an old turbo vehicle on power-to-weight. Wait till january or risk getting caught. A great way at not getting caught is to not drive like a moron and do skids or weave traffic etc. a lot of people seem to forget that.
Yes but its in Japanese.  Someone may have it on a site where you can download it quickly. Its 353,788KB
OK 2 or 4WD?
Page 9 of the manual gives the power as 173KW @ 6400 rev/min
and page18 gives the weight as 1795kg
  • 3 weeks later...
Hey does anyone have an eEnglish version of the manual stating the given stuff? I've applied for the exemption but they are saying I need to get it translated. So thought I'd just ask on here first, just in case anybody has one. Thanks.
OK 2 or 4WD?
Do you have a clearer copy of this by any chance? I'm trying to get it translated and the translator said they cant quite read the page showing vehicle weight and such. Thanks.
Try JPNZ International. I bought a translated owners manual for a series 2, so different power and weight. I bought it 8 years ago so not sure if they will still have it.
[email protected] or
www.jpnz.co.nz
I'll try and upload them in landscape as they seem to be bigger that way...yep if you click on these they come up quite well.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
