So I have a 1998 Nissan with a 14 pin consult port.
I have a problem with my ABS system and wanted to do a diagnosis to find out what the issue is but I cant find a software that supports it. I know NDSII supports ABS but this is the the 16 pin rather than the 14 pin that I require.
If anyone could point me in the right direction that would be super duper helpful
TIA
https://www.sau.com.au/forums/topic/475000-abs-ecu-consult-software/
Off topic but I wrote some software to connect to the ABS/ETS computer in my R34 GT4, via consult port.
Are you sure you can’t put the ABS in diagnosis mode by connecting some pins? You need a workshop manual for details. You can do this on R34 for example, it flashes error codes on the brake warning light on the dash, similar to engine ecu diagnostic mode.
