Hey guys i just recently got my r34 manual converted. since i have had it back it has been running slugish (worse then my NA r34).
so while driving it the boost gauge goes up in boost and you can hear the turbo spooling but it feels like i am not getting any boost at all!
the part that seems weird is that it seemed to drive normal when cold? (felt like it had boost. i didnt test that to ghard though since the car was cold)
any help would be much appreciated, thank you
https://www.sau.com.au/forums/topic/475161-r34-turbo-issue-help-please/
1 minute ago, wildeagle44 said:
Is the car tuned or stock?
I’d be checking the timing or having a look at the knock sensors.
Recently filled up with fuel? Could be a bad batch.
Hey mate. Everything is stock expect the exhaust with is a hks.
No cant be fuel, i havent filled up since the conversion and it was running great before when auto.
Does it matter that its still running auto ecu?
Ok thanks i will have a look at those sensors, is there a way to test them?
Auto ecu shouldnt matter
I would check by plugging a computer into the consult port, there might be a way to check with a multimeter, maybe look up the service manual.
Only other things i can think of are check for boost leaks or a blocked cat converter.
  • Thanks 1
Really a blocked cat can do that?
Ok thanks mate. I will have to find a diagnostic tool with the consult end or take it to a shop.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
