Hi and welcome to :sau:
Do you have a multimeter? What happens when you touch the bulb terminals with the points? Do you get any voltage?
Have they ever worked?
Can you unplug all except the 3rd light to test?
https://www.sau.com.au/forums/topic/475199-hello-please/#findComment-7888330
19 hours ago, admS15 said:
At a guess, im going to say the switch at the brake pedal.
Question... never had this issue before to I noticed that when I push the brake the brake switch disengages... quickest way to find out if the circuits working? Multimeter? I brought a test light but the damn thing doesnt work
Thanks too for your help
https://www.sau.com.au/forums/topic/475199-hello-please/#findComment-7888399
3 hours ago, rjmparker said:
Right shi# f#*k... I have power at the switch but no power at the fuse box???!
Elp please
Sure you have the right fuse? 15amp one in the middle? With the key on you have no power either side of the fuseholder (one probe to earth and the other testing each side one at a time)? Tried a new fuse just to be sure? You have power at the switch but does the switch work as it should (circuit completed when brake pedal leaves it)?
https://www.sau.com.au/forums/topic/475199-hello-please/#findComment-7888483
Fuse is right fuse... I'm going to recheak the circuit, this shits doing my head in, and car was running when I was testing the fuses
https://www.sau.com.au/forums/topic/475199-hello-please/#findComment-7888519
If you have power at the switch the fuses are probably fine. Concentrate on the switch - is it moving freely when you push the pedal down? You have power one side of the switch do you have power the other side when the pedal is depressed? If not adjust or replace the switch.
https://www.sau.com.au/forums/topic/475199-hello-please/#findComment-7888526
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
