44 minutes ago, FizZe said:
I dont want recommendations telling me to save up to buy a GTR or a better car once off my P plates I would like some genuine advice about putting a turbo on my car plz. Also money is not an issue.
Take it to a shop and tell them money isn't an issue. Wait a while and bam, done.
You've heard it a million times and annoying as it is, doing a turbo engine swap or whatever would be the best way to go. Turboing a RB20 won't make crazy power unfortunatly or be close to your expectations. If you're planning on keeping your R33 for a longtime, going for a RB25DET would be best in terms of cost, power, time, etc.
If you're really set on turboing your RB20, then from the top of my head you'll be needing the following bits and probably more... Also keep in mind you probably won't be able to push anything more than 7psi of boost safely on stock internals and you'll need to upgrade your brakes and stuff aswell.
Use factory or replacement turbo parts is up to you...
-RB20DET/RB25DET turbo or something else
-Intercooler
-Uprated fuel pump
-Bigger injectors
-Chipped RB20DE ECU, RB20DET  or something else
-Manifold
-Turbo downpipe, exhaust, etc
-Oil & water lines
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
