Damn R32s are getting had to find in South Australia!!
have had one in the shed for around 4 years now and planned on putting 180sx rocket bunny flares on it, like the pic below.
the front fine, can always get new front guards if i hate it, BUT the rear is a lot of cutting and theres no going back from it.
I just dont know if i can bring myself to cut it!!!
never thought id say that about a run of the mill 32 gtst!!!!!!!!!
https://www.sau.com.au/forums/topic/475269-r32-skylines/
If the R32 in question is in good nick, please don't cut it up.  I have no problem with people abusing cars that are already f**ked up, but there are so few good R32s left now that it would be a real shame to deliberately damage one, even if it is for teh cause of making it look pretty cool (I like the Rocket Bunny look).
  • Like 1
https://www.sau.com.au/forums/topic/475269-r32-skylines/#findComment-7889409
im just really struggling with it haha
on 1 hand i can have a wide car and put some awesome rims on it........
on the other hand i dont know if i can bring myself to cutting it up, theres no going back. but never found a set of rims i love on a standard / rolled 32 gtst
https://www.sau.com.au/forums/topic/475269-r32-skylines/#findComment-7889474
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
