I have a r33 gtst ( auto ) and it’s stock apart from a front mount intercooler, carback exhaust and pod filter.
It runs fine up until 6psi but once it goes over 6psi the car cuts out and jolts foward ect . Can’t figure out if it’s a boost cut or fuel cut or why it’s happening.
Currently running 7psi with a manual boost tee
Any ideas what it could be? Have checked the afm and it seems fine, vacuum lines are fine and can’t find any boost leaks ( it holds boost as long as it’s less than 6psi )
im thinking it might be coilpacks, spark plugs or tps but don’t really want to start buying parts until I know what I need so I don’t replace stuff that isn’t broken
https://www.sau.com.au/forums/topic/475496-r33cutting-out-at-7psi/
How high in the rev rang do you hit 6psi before this happens?
Do you have any aftermarket ECU?
Read this topic.
https://www.sau.com.au/forums/topic/336073-r33-rb25det-cutting-out-on-boost/
Read this topic.
The tacho doesn’t work but I’d say it’s somewhere around 4-5k revs
stock ecu
Update: have changed spark plugs ( regapped to 0.9 ) and it seems to have stopped the boost cut but now it’s misfiring under load, changed the coilpacks too and didn’t change anything.
Is fine if I drive really quiet but if I put my foot anymore than half way down it just sits there farting . Any ideas what could be causing it? Will have a look at the fuel pressure but I’m thinking it’s something to do with the plugs as it got worse when I changed the spark plugs
wouldn't surprise me if both sets are cooked... Borrow set of decent coils that aren't yellow or red in colour.
If S1 check ignitor/swap it AND check the ignition harness (clean or replace or hit it with WD40)
if S2 check the ignition harness (clean or replace or hit it with WD40)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
