That's pretty bad milage... I get about 500km on my S2 Turbo Auto Stagea and I do put my foot down occasionally. The O2 Sensor is the cheaper part to replace first but I would say the AFM may be playing up as that's pretty much double the fuel you should be using...
Check your spark plugs too.
PEC O2 sensors I've found we're good for my Skyline and Stagea. Stagea now runs around 12.5L/100km with a new O2 sensor and NGK spark plugs and my R33 Turbo Sedan is 8.5L/100km at best. But usually 9L/100km. It went from 15L/100km to 9L/100km just from getting a new O2 sensor from PEC Online.
https://www.sau.com.au/forums/topic/475571-fuel-economy/#findComment-7893532
And measure your fuel consumption in l/100km. Your gauge could be wrong...not even sure what 250km per tank means. If you are heavy footed and drive mostly in the city racing from light to light you could use a lot of gas.
https://www.sau.com.au/forums/topic/475571-fuel-economy/#findComment-7893560
1. Full tank the car (with 98 RON petrol)
2. Drive around normally for 200 km
3. Full tank the car again, record how many litres you put in
4. Divide that litres reading by 2, post it here
5. Look for air leaks in the intake, search for "AFM solder fix" in this forum and follow that guide (get a spare AFM while you're at it), inspect/change oxygen sensor if you haven't already (as GTSBoy mentioned).
There could be other things, you haven't mentioned any mods done to the car (engine related).
For reference, my Subaru wagon does 10-13L/100km depending on driving (2.5L turbo manual).
https://www.sau.com.au/forums/topic/475571-fuel-economy/#findComment-7893777
My C34 Stagea with a big turbo would do 15L/100 round town if pushed regularly or 12 taking it easy. On a trip at a steady 110 with the odd passing burst about 9L/100km
At the track would empty the tank in minutes (only slight exaggeration).
https://www.sau.com.au/forums/topic/475571-fuel-economy/#findComment-7893825
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
