  • Replies 81
One with semi slicks, obviously driven hard, with the right bits (coilovers, turbo, brakes etc) and a cage/stripped interior.
or
one that uses the old adage, "actions speak louder than words" ie - is known for its performance, not its looks (belgarion etc)
