I’m gonna be looking at purchasing a turbo in the near future and I’m on the fence with either a hypergear or mambatek or also a gtx2860. So my question is has anyone ever fitted a Garrett to their stock rb20 manifold and if so what all did you have to modify to make it work? I was thinking about purchasing the five bolt flange and just have that welded to the tomei 3” downpipe instead of its six bolt flange. Like so
The manifold side is easy, per Josh's point 2 above.  But I think the OP question is more to do with the dump pipe side.  In which case, don't f**k about with cutting and shutting a new flange onto the Tomei dump if you don't already own it.  If you do already own it, it might be doable.  But I would just get a new dump made up.
Right my question has to do with just the dump side. Or would it be do able to use the exhaust housing side from the stock turbo and switch it over to the Garrett turbo to keep the six bolt flange and not have to do any cutting welding or making s new dump. And no I don’t have the tomei dump in my possession.
yes do what he ^ said.
If you really feel like f**king around then the garret 5 bolt is the same as SR20 so you could buy an SR20 dump and then cut it 30cm down from the dump where its a 3" and try and make it fit.
but don't do that. Do what GTSBoy said.
if you're keen, I have a ATR45SAT with a 3" v-band rear, 3.5" dump/down pipe, cat, 4" intake & oil catch can to suit.
Just need to weld on an external to the rear housing OR onto your manifold and done. Everything bolts up tits, maybe just need to mod the cat back to line up.
$1300 + supporting mods = 400kW+
And I’m in the states as well. Shipping could be a pain. And we don’t need a cat where I live. Emissions free zone ???
You almost never get better results (or results that are worth it) from cutting any corner ever in a turbo setup.
If making a dump pipe up is too expensive/hard/unfeasible due to cost the best answer is wait, or get a highflow turbo made up and shipped by Hypergear (though I am not sure what he suggests for a RB20DET).
In all my boosted cars I’ve never cut corners especially with boost. I e mailed Garrett and am seeing if they can make a gtx2860 with the Nissan hot side. If hypergear has one in stock instead of me having to ship them my turbo I’d be okay with that.
The thing is, ultimately if "I have to get a dump pipe/exhaust fabricated" removes the thing from being a viable choice... then sad to say it/budget is not ready. The rest of it requires far far more time, money and thought than the dump pipe fitting up.
"Just get a dump made up" is about as much as anyone thinks about this particular issue because it is a 1 second throwaway, obvious answer at no/minimal cost. I get that it may be harder to obtain in the USA or find a fabricator where you are, but that just means all the more expensive, more complicated stuff is going to be equally hard or harder to find.
  • Like 1
Fair point. I guess I’ll have to stay stock turbo than.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
