I’m gonna be looking at purchasing a turbo in the near future and I’m on the fence with either a hypergear or mambatek or also a gtx2860. So my question is has anyone ever fitted a Garrett to their stock rb20 manifold and if so what all did you have to modify to make it work? I was thinking about purchasing the five bolt flange and just have that welded to the tomei 3” downpipe instead of its six bolt flange. Like so
The manifold side is easy, per Josh's point 2 above.  But I think the OP question is more to do with the dump pipe side.  In which case, don't f**k about with cutting and shutting a new flange onto the Tomei dump if you don't already own it.  If you do already own it, it might be doable.  But I would just get a new dump made up.
Right my question has to do with just the dump side. Or would it be do able to use the exhaust housing side from the stock turbo and switch it over to the Garrett turbo to keep the six bolt flange and not have to do any cutting welding or making s new dump. And no I don’t have the tomei dump in my possession.
yes do what he ^ said.
If you really feel like f**king around then the garret 5 bolt is the same as SR20 so you could buy an SR20 dump and then cut it 30cm down from the dump where its a 3" and try and make it fit.
but don't do that. Do what GTSBoy said.
if you're keen, I have a ATR45SAT with a 3" v-band rear, 3.5" dump/down pipe, cat, 4" intake & oil catch can to suit.
Just need to weld on an external to the rear housing OR onto your manifold and done. Everything bolts up tits, maybe just need to mod the cat back to line up.
$1300 + supporting mods = 400kW+
And I’m in the states as well. Shipping could be a pain. And we don’t need a cat where I live. Emissions free zone ???
You almost never get better results (or results that are worth it) from cutting any corner ever in a turbo setup.
If making a dump pipe up is too expensive/hard/unfeasible due to cost the best answer is wait, or get a highflow turbo made up and shipped by Hypergear (though I am not sure what he suggests for a RB20DET).
In all my boosted cars I’ve never cut corners especially with boost. I e mailed Garrett and am seeing if they can make a gtx2860 with the Nissan hot side. If hypergear has one in stock instead of me having to ship them my turbo I’d be okay with that.
The thing is, ultimately if "I have to get a dump pipe/exhaust fabricated" removes the thing from being a viable choice... then sad to say it/budget is not ready. The rest of it requires far far more time, money and thought than the dump pipe fitting up.
"Just get a dump made up" is about as much as anyone thinks about this particular issue because it is a 1 second throwaway, obvious answer at no/minimal cost. I get that it may be harder to obtain in the USA or find a fabricator where you are, but that just means all the more expensive, more complicated stuff is going to be equally hard or harder to find.
  • Like 1
Fair point. I guess I’ll have to stay stock turbo than.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
