I have 95 s14 with a series 2 rb25det
Car is not running right and have spent lots of money trying to diagnose it and the compression number for cylinder 6 is more 10% different than others, so was gonna either buy another rb25 or swap a rb26 in it.
I will already have the rb25 trans, what else would I need
New wiring specialties harness?
Can I use my top mount exhaust manifold with adapter plate?
Will the engine mounts be the same?
Will the driveshaft be the same? 253391A2-9FA1-4C20-85FE-867ACBD18C96.thumb.jpeg.7cd59a720d017d3127cde51dba3cc60c.jpeg
If I can use a lot of the same parts I will rather get the stronger engine and safe the long term hassle of pushing higher hp numbers..
Thanks in advance for any input!
List of mods on car now
RB26 does not have lower mounting points for gearbox cast into the block, the 26 has the gearbox mounting points in the sump. The RB25 uses two pressed steel mounts that bolt to the block and gearbox
Edited by Rusty Nuts
23 minutes ago, RbLovee8 said:
Okay so why do they say use the rb25 trans with that swap set up?
Don't know who "they" are mate i'm just stating the facts, I personally would not run a Rb26 with no lower bolts connecting the gearbox to the engine for obvious reasons, I also don't see why you would bother, I would sort out your current configuration
I was hoping to achieve 400-500whp easier and be more reliable at the same time
Lol stock RB26 is probably less reliable and more $$$ to get more power out of than RB25 (even with single turbo). I reckon get your current motor checked out, or replace it (depending on engine prices/shipping for you)
Yea after thinking and looking at all the prices I’m going to just get another rb25 engine, and just build the current engine stronger
Before you buy another engine, pull the head off your compression problem could be just valve related (ie sticking valve)
or simply head gasket, diagnose first, spend money second.
  • Like 1
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
