This is the current setup for my catch can which I did not do, have been freshening up everything I am now up to redoing the catch can setup and this doesn’t seem right (pipe from turbo intake???)
Don’t have any of the standard pipes on the hot side any more just what you see
Pic is of my actual engine bay
I no it’s been talked about before
But can’t seem to find any real help to my application if it’s right or not
Just want to no how to setup properly with what I have
Any help greatly appreciated
Cheers
https://www.sau.com.au/forums/topic/476058-help-needed-with-catch-can-setup/
No just straight through into can
Why would it have pipe from turbo inlet ? Suck it straight through into turbo I would have thought
The ally catch can I have has no steel wool or anything just a can with drain plug
Have a new can on the way with steel wool filter thing
Want to setup the pipes right
The way it is set up is broadly the same as the NIsmo can if that makes you feel any better.
You put a restrictor in it so the turbo doesnt hoover the guts out of your can and taking the oil with it.
Dont use steel wool, use a sintered brass item as per mishimoto.
https://www.mishimoto.com.au/automotive/oil-catch-cans.html
Edited by djr81
Routing as stated looks fine.
Catch can/oil separator system is more than some steel wool.
You really need some baffles in it, or a cyclonic effect to strip the oil out of the air, maybe fuel foam, but, whatever the design, make sure you can service/replace the "steel wool" or fuel foam, ALSO, steel wool can break down and end up on your intake, and fuel foam gets clogged with gunk.
Baffles/fuel foam in the cam covers help, ?Mines???
Ok great thnx guys good to hear setup was sort of ok to start with
Except no baffle
This is the kit I have on the way
This should do the job then yeah? Twin filter/baffle
Any other recommendations??
Yeah ok then, it is a street car
I can just put 2 bungs in so it’s not vta
So non vta should be legal ?
Even though it’s running a screamer pipe [emoji108]
(They haven’t found that yet) would rather it be legal, easy to see the catch can and never had an issue with current setup with them
Except no baffle
Too small. Don't need breathers. As above read the oil control thread if you have a problem (maybe start half way through):
https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/?tab=comments#comment-2039323
On 2/20/2019 at 11:58 AM, r33cruiser said:
What about the JustJap style cans?
Retain window washer and it fits perfectly:
http://justjap.com/sri-alloy-oil-catch-tank-nissan-skyline-r33-r34-gtr.html?___store=default
What baffling is inside though?
I'm not personally sure mate. But the JJ boys have always been very helpful to me, I bet if you call them they'll help you out.
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
