This is the current setup for my catch can which I did not do, have been freshening up everything I am now up to redoing the catch can setup and this doesn’t seem right (pipe from turbo intake???)
Don’t have any of the standard pipes on the hot side any more just what you see
Pic is of my actual engine bay
I no it’s been talked about before
But can’t seem to find any real help to my application if it’s right or not
Just want to no how to setup properly with what I have
Any help greatly appreciated
Cheers
https://www.sau.com.au/forums/topic/476058-help-needed-with-catch-can-setup/
No just straight through into can
Why would it have pipe from turbo inlet ? Suck it straight through into turbo I would have thought
The ally catch can I have has no steel wool or anything just a can with drain plug
Have a new can on the way with steel wool filter thing
Want to setup the pipes right
The way it is set up is broadly the same as the NIsmo can if that makes you feel any better.
You put a restrictor in it so the turbo doesnt hoover the guts out of your can and taking the oil with it.
Dont use steel wool, use a sintered brass item as per mishimoto.
https://www.mishimoto.com.au/automotive/oil-catch-cans.html
Edited by djr81
Routing as stated looks fine.
Catch can/oil separator system is more than some steel wool.
You really need some baffles in it, or a cyclonic effect to strip the oil out of the air, maybe fuel foam, but, whatever the design, make sure you can service/replace the "steel wool" or fuel foam, ALSO, steel wool can break down and end up on your intake, and fuel foam gets clogged with gunk.
Baffles/fuel foam in the cam covers help, ?Mines???
Ok great thnx guys good to hear setup was sort of ok to start with
Except no baffle
This is the kit I have on the way
This should do the job then yeah? Twin filter/baffle
Any other recommendations??
Yeah ok then, it is a street car
I can just put 2 bungs in so it’s not vta
So non vta should be legal ?
Even though it’s running a screamer pipe [emoji108]
(They haven’t found that yet) would rather it be legal, easy to see the catch can and never had an issue with current setup with them
Except no baffle
Too small. Don't need breathers. As above read the oil control thread if you have a problem (maybe start half way through):
https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/?tab=comments#comment-2039323
On 2/20/2019 at 11:58 AM, r33cruiser said:
What about the JustJap style cans?
Retain window washer and it fits perfectly:
http://justjap.com/sri-alloy-oil-catch-tank-nissan-skyline-r33-r34-gtr.html?___store=default
What baffling is inside though?
I'm not personally sure mate. But the JJ boys have always been very helpful to me, I bet if you call them they'll help you out.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
