Hey guys, an update.. bad news kinda.
Well, seemed that there has been a fair bit of work needing attention on the engine (including a f***** new gasket!!). Thus the car would only be getting to Canberra mid-this week. Now, seeing as I'm taking a break and going up to the Gold Coast for Christmas (where the car currently is) I have decided that the cost and wear on the car is not worth bringing it down here for the time left before I'm on holiday.
Thus, the car will not be here till next year!! (When I do the return trip to Canberra). Dunno if I'm coming to Summernats, depends what the turn out of skylines and mates are gonna be there so we'll see. Anyways (sry bout the length of the post), I'm going early next week so look forward to seeing everyone next year and unveiling my car. I know I havn't made much of an appearance so far, but I'll change that next year :).
Good Luck to everyone over the new year. See you all soon
You're game putting a skyline in Summernats. usually the bogans don't like their presence. i was thinking of going in the sound off only, but basically i'd rather not get the car kicked in or keyed.
Yeah I was thinking that, xept I'm planning on going with my brother and another couple of mates... a rocket VN wagon and showy VT from the Gold Coast.
But yeah, proly won't end up hapnin, I care too much bout my car... still go c the show tho :D
  • 3 weeks later...
sounds nice :rofl: Stupid question though you say you have a 300zx turbo running 14psi would that not be making alot less power than a standard rb20 turbo ??? only reason i ask is i though all 300's were a 3L twin turbo thus each turbo is designed around a 1.5L engine ??? correct me if i am wrong
Leigh
Hi everyone!
First post.
1989 GTS-t 4 Door
3" Exhaust From the Turbo back
Fuel Pump
Suspension
300ZX Turbo running 14psi
Turbo timer and imobilizer with remote start.
Good sound system.
Pretty standard affair.
Only got it last week!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
