Hey all, was hoping you guys could help me out with this one. I'm looking at purchasing a pair high flows cats, i have a 2003 nm35 stagea and pretty much all the parts im looking at, at the moment are for the infinity g35 and nissan 350z, im currently hooked on purchasing one from z1 motorsports and purching thier z1 highflow cats for the g35 de model, now all i need too know is if the catalytic converters are the same on the g35 and my stagea. if so i know it will fit, ive already looked a ton and from what i can see they look identical but just need too make sure before i go through with purchasing something from overseas which is pricey. i couldnt manage too find anything local as of yet hence why purchasing online and was going too get it custom done but the guy didnt look too keen on doing it and quoted me far more then i could afford soo only got everything from the mid pipe back done. but if any of you know any high flow cats which are a perfect fitment and/or if the g35 runs the exact same cats as the stagea would be a great help.thanks!
https://www.sau.com.au/forums/topic/476280-high-flow-cats/
2003 nm35, is it a vq25det? If yes, the cat is built into the dump pipe on the back of the turbo. Very few aftermarket options. Scotty's customs used to make his own, not sure if he still does it. Am performance in SA is another one.
Pnm35 is a vq35 and the cats you are talking about in your original post may fit.
https://www.sau.com.au/forums/topic/476280-high-flow-cats/#findComment-7900300
5 hours ago, GTSBoy said:
Buying cats "that fit" is not the only way to do it.
The only way I have ever done it is to buy the cat I want, without flanges, then weld the flanges to suit the car.
Yea I know of that way of doing it but I can't weld nor own one, and would need too take it somewhere and pay for that as well, just looking for something with direct fit so can do myself. if nothing then will have too go with getting it custom done or like you said.
https://www.sau.com.au/forums/topic/476280-high-flow-cats/#findComment-7900303
No it's the vq25dd should of mentioned that too sorry, no turbo and I do believe I have the same manifold as the pnm35 and infinity g35, all run the same manifold I'm sure from photos. correct me if I'm wrong, soo that's believing me too think their cats are the same too, they look almost identical besides the fact they have o2 sensors in them. Just from the videos of installs I've watched its like as if it's longer in length then mine, but will do more research. Thanks heaps
https://www.sau.com.au/forums/topic/476280-high-flow-cats/#findComment-7900304
Ok, i see. Next question is why you would want to get high flow cats for a vq25dd? They are unlikely to make a big noticeable difference. High $ for low gain. Doesn't really make much sense to me.
Personally i would leave the stock ones in there.
https://www.sau.com.au/forums/topic/476280-high-flow-cats/#findComment-7900306
Honestly it's just the car I have haha and it's become a little project too me I understand there not much gain in it, I just wanna get a bit more power out of it anywhere I can and also my stock cats are making a very weird sound and looked almost cracked and rusted down there. Also want too change the tone coming out of my exhaust as I just got a custom exhaust from the mid pipe back done, and it's got a very deep low tone at about 2000 - 3500 rpm if I explained that correctly haha soo was hoping new free flow cats could change that tone possibly. I'm still learning. And oem cats I heard are pricey soo thought. Might as well upgrade if possible
https://www.sau.com.au/forums/topic/476280-high-flow-cats/#findComment-7900308
OK still cheaper to buy from Venom than from the States. Or just take them off, knock the guts out of them and put them back. And to change the tone get a resonator and put it in the middle of the exhaust.
Or for more power buy this:
https://www.trademe.co.nz/motors/car-parts-accessories/nissan/engines/listing-1978090441.htm?rsqid=f103349f7adf4ca483c59d5837e3cbe4
https://www.sau.com.au/forums/topic/476280-high-flow-cats/#findComment-7900310
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
