Hi guys
i know this question has been asked but wanted some assurance before buying it and pick your brain
tuner told me the car is loosing around 20-30 bhp when hot so my plan was to get water injection to cool it without futher tune
i did and fully installed. It is the aem and recommand 50-50 water and methonal mix
i know wwater won’t burn and it will only cool the temp and do know meth burns but has a very high octane
i also know if you inject too much water you can get hyro lock or have a very rich mixture casuing engine damage
injector is progressive with start psi to full psi
my question is , could i set it so it injects water/ meth to cool intake without needing a retune?
my max boost is around 17 psi and i plan to set it so it comes on at 8 psi and progressively injects more as it gets close to 17 psi.
re water, would you put mineral water or tap water. Most people say de ironised but does it matter if i put tab water in?
re methonal, i know it is a cheminal and googling comes up with hundrands of them from 95% pure and above. Is there a specific meth i need to get or whatever?
in cold season can you put antifreeze to stop it freezing?
Methanol like this?
https://www.ebay.co.uk/itm/Methanol-Virgin-Grade-99-5-for-Biodiesel-Racing-Fuel-Fuel-Cells-2-X-5-L/123336905100?hash=item1cb773d18c:g:FzEAAOSwzU1bhQxa
https://www.sau.com.au/forums/topic/476553-methanol/
Your tuner sounds weird. Your car is losing power when hot? So you put your car on the dyno and it makes X bhp and when it warms up it makes x -30 bhp? Is he saying it is overheating?
Water/methanol injection is a whole other subject but no you won't need anti-freeze. Methanol is an effective anti-freeze....
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902229
1 minute ago, drifter17a said:
He said it is getting hot on intercooler and it is making changes to produce less power...
It is easy for intercoolers to heat soak on dynos but maybe you need a better intercooler.
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902231
You don't need WMI for what you problem is.  It sounds like your turbo is making the air waaaaay hotter than it should. You should first investigate what the hot side air temp is under load.
WMI is a bandaid in this situation.  You'd be better off finding out what is actually wrong and dealing with it.  That might mean a different tuner, because this guy's clearly not able to punch through the evidence to the source.
And, to answer your specific questions.....yes, demin water is required because tap water has salts in it that dry and deposit when it evaporates.  If you think about the process you are using the water for, I think it will become obvious why that is important.  And methanol is methanol.  Any industrial grade near pure methanol will be fine, so long as the balance of the mix is not something bad, like formaldehyde.  If it is 95% meth and balance water......
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902233
Well tuner has locked the map so not much choice as i have to pay a full fee for someone else to remap
it is not connected yet but i noticed it had finished one gallon on my way back ( pipe is in engine bay under filter) until i weld a bung
seeing that and also the fact that methonal is dangerous to store, i am thinking of using water only with no meth to keep it cool
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902278
Well i was thinking of mixing it with water and store but currently not living in house so will be stored in bathroom and feel a bit uneasy on it
if you mix methanol with water, does it loose its burning quality or ignite as quickly
for instance fuel doesn’t mix with water but not sure if this is the case for methanol
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902283
There another reason to no do it.
50 50 methabol and water doesn't burn and yes it does mix, how the hell would everyone be mixing it if it didn't mix?
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902285
So you already have it?
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902286
14 hours ago, drifter17a said:
yes have it and installed. taking it to a shop to weld the bung so can insert the nozzle into intake
as it stands it is hanging in engine bay safely !
so 50 50 water meth does not burn ? What is the point of adding it then ?
You also don't need to weld a bung. The stock crossover pipe is plenty thich enough to drill and tap.
Also I don't really put much faith in a progressive controller based on boost. You can be at full boost low revs and get full flow, it really needs to be mapped to the actual engine demand (injector duty cycle) for progressive to be worthwhile. Even then there are issues.
You need a tune by the way
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902408
I'm at the point now of wanting to egg Drifter on.  I really think that an un-planned, non-understood WMI implementation running at full stink with no tune is going to add wonderfully to the catch-can oil loss problems in a delightful way. I'm just sad that being on the opposite side of the world, we shall likely be unable to see the resulting mushroom cloud.
  • Like 3
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902409
Actually the car runs really good and link ecu is mapped so when temp is high then boost is dropped
when temp is around 25 degree the boost goes to maximum of 15.5 psi
now temp is around 16 degree and boost at 17 psi. Water only
Aem says the injector has to be above the tank so gravity won’t pull
that is my difficulty now as i want the injection to be right after intercooler so temp is dropped by the time it is at air temp sensor but that is presenting a problem as it is lower than the tank so testing this gravity pulls water even when off
this is when the pipe is off the injector and hanging but as soon as it is inserted , it does not seem to leak. I have filled the tank to the lip and not a single drop when plugged in
i can only assume because there is a nozzle and it is small, it is cancelling the gravity or water can’t flow same as when it is unplugged
my question is , is there a valve or something that opens under pressure so i can insert it meaning gravity can’t pull water and once the pump injects that is only when it opens?
here is a pic of the nozzle
https://h-tune.co.uk/aem-v2-water-methanol-nozzle-and-jet-kit/?currency=GBP&gclid=EAIaIQobChMIlrCiwKrL4QIVLrXtCh3X_QPuEAQYAiABEgJmS_D_BwE
am i correct thinking it is check valve?
Edited by drifter17a
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902761
That's completely ridiculous boost limiting strategy based on those inlet temps. The tuner sounds special.
Also, the best thing is a solenoid valve, the next best is a check valve. This isn't rocket surgery.
https://www.sau.com.au/forums/topic/476553-methanol/#findComment-7902793
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
