On 12/01/2022 at 6:39 PM, Blitz said:
Eastern suburbs for now but looking at houses on the lower north shore or northern beaches at the moment.
Eastern suburbs? Yikes, what happened to you?!? :rofl2:
On 12/01/2022 at 6:45 PM, Blitz said:
I could ask the same of you - Are you a BMW fanboy now? 😏
I'm an everything fanboy. I seem to want one of every car atm. If only I was a middle eastern prince. :)
Unfortunately, cars are a little lower on my priorities than they used to be. Just moved house and have a daughter going into fricken year ten and another in year 7. Its all doing my head in.
Living the dream :) An unlimited garage and bank account would be nice wouldn't it?
Absolutely. And time to drive them! I bet that GT3 is fun. Totally a fave of mine.
Believe it it not, I have barely driven it. Bought it earlier this year, it arrived the day before my daughter was born so free time wasn't something I have had a lot of, and then we went into a 5 month lockdown and I wasn't able to get to it.
I'm happy to keep it warmed up if you want :)
Congrats on your daughter!!! Is she your first?
On 12/01/2022 at 7:27 PM, Duncan said:
fark. That does my head in
Yep. Eldest gets her license this year. Need to find a big open space to let her let it rip.
On 12/01/2022 at 8:12 PM, B-Man said:
Hay Boys. Good to hear everyone is happy and safe.
Holy smokes, b-man! Long time! How's things?
I'm OK mate - Miss my Skyline, Gloria, Cosmo (ie anything Jap Import) - Still living in Adelaide. Having kids kills the ability to have car projects...... so waiting for them to all move out (11 years to go !) LOL.
20 Years for SAU, that's wild - I still remember my first meet up with you guys, even before I had my GTST. I had the Red VL Turbo and we cruised the Northern Beaches.
Good Times.
Good Times.
If you weren't SDU before you were SAU, are you even OG? 😀
Car projects are still doable with kids B-man, its the time to enjoy them part that is the issue.
Where in radelaide are you living? DM me if you like - We are down there regularly.
Are you on crack. 4 kids, wife doesn’t work, Adelaide wages. Car projects not happening.
  • Sad 1
So, while @Duncan has stretched the definition of 'Northside' somewhat, I'm seriously impressed by @B-Manincluding himself from Radelaide. :rofl2:
You have an E500 though, thats super cool.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
