Hey guys, Ive read a tonne of posts about this, but most seem to either be about race car camber or lean into a different direction.
So quick info about my situation, driving to work in an r34 25gt, and my front tyre busted, massive wear on the inside, got new tyres and an alignment, the mech said he could only get the camber to -2°, but as mine is a daily and a 25gt, I'm not looking for much camber, would like to get back to even wear on tyres maybe -.75°/-1°.
Been looking at adjustable upper camber arms, (just incase I ever get rims or decide to lower it) but wanted reviews before I buy, just incase some are notorious for easy breaks, squeaking/clunking after a short time etc
The ones I've looked at are:
SRI - $220
Gktech - $349 (so far thinking these ones)
Zss - $459
Cusco - $479(heard they are really good for price)
Driftwork - $216
Hard race - $499
I looked at ikeya formula, but too expensive for a 25gt. Has anyone had good/bad cases with any of the above arms?
Sorry if I've forgotten any details to include for further help.
https://www.sau.com.au/forums/topic/476716-r34-adjustable-camber-arm-reviews/
Completely stock height and wheels, I asked the mech what was causing the negative camber and he couldn't tell me, just said I need aftermarket adjustment parts, I asked if anything was bent or seemed damaged and he said no. So how would I go about finding what's caused it? I've never really worked on suspension so I'm outta my element.
The car has *some* adjustability and there's bushes you can get from Whiteline or Superpro that will adjust camber that is more than enough for a stock height car. They are cheaper, legal, more compliant and overall a better solution that what you listed..
That said, there IS a problem if you can't get less than 2deg neg camber on a stock car. Fixing this is definitely what you would/should/must do first before buying aftermarket arms to sort it out.
This is definitely a "Find someone who knows what the underside of these cars should look like" situation
Ok ill call the smash repairs and see where they get chassis straightening done, but cars never had a crash or anything so not sure if chassis is damaged but worth a look, I might even get a 2nd place to try and align it, as I read a post on SAU where someone had the same deal, 1 place couldn't align it, but another could, the mech could be trying to stitch me up for extra work.
We have have a 25GT with standard suspension, the front and rear camber is pretty close to neutral with little to no wear on the inside.  Common for cars that are lowered on springs or coliovers to exert excessive rear camber, is your issue on the front or rear?
JGTC it's front suspension that's my issue, but I may see if I can get the stuff gtsboy stated above checked out, cause I've never had a problem with wheel alignments till now, recently replaced the right control arm as the ball joint was buggered, and the radius arm bushes. So ill get the other bushes and arms checked, but thought they would notice something wrong when doing the alignment, i also jacked the car up and had a look and couldn't see any other damage, besides what I've gotten fixed.
That's what I'm thinking, had a look myself (I'm a fkn noob) noticed the radius arm bushes and ball joint, but didn't notice anything else, really hoping I fall in the category of having a shite mechanic, will book in with another place, ask for stats of camber, toe etc, and post for you pros to help me, appreciate the help from all, glad I didn't buy the arms. This is why I love SAU.
I run around 2.75 deg neg front camber on a daily driven street car, and i have very little issue with inside tyre wear. Toe, worn components or bent arms/chassis are likely to be the real issue.
  • Like 1
So I was a victim of a shoddy mechanic, went to a new place today for an alignment, and afterwards they said they got it down to -1°. Which I'm happy with. Turns out the toe was the culprit. Glad I asked SAU before buying camber arms. Cheers fellas.
  • Like 1
  • Haha 1
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
