Hello, i have been searching for gearboxes for a while now and i cant really make up my mind.
The car will be street driven so the gearbox must have a reverse and be able to downshift by itself etc.
Seen some people using powerglide t400 / t700 and liberty gearboxes etc, but the liberty gearbox (clutchless) seem to be pain in the ass for roaduse?
anyony got any suggestions here? the gearbox must hold for atleast 1200 bhp
Best regards
Nice street car with 1200hp.. Powerglide or th400 are your only choices really.. Mate owns a 1000hp GTR and commented on the sequential being a little rough for a streeter.
Really depends on the type of racing you plan on.. auto would be bit average for circuit, holinger would be ok for drags. mentioning liberty leads me to believe its a street drag car?
Edited by azzada1
unsure what you mean by a little rough, although I am only around the 800whp mark, I find the holinger perfectly streetable, obviously using the clutch as cruising around for daily driving.
Wow, First you wanted an OS giken or PPG synchro gearset, and now you're talking Autos ? WTF ? That's a pretty dramatic difference between setups. If you go the auto route it is basically a "street registered" drag car. C'mon if it's got an auto in a BNR32/BCNR33/BNR34 to me it is hardly a GTR anymore.....
At least the sequential dog boxes have a certain amount of "having your cake and eating it too", as they can be streeted, can be circuited and can be drag raced all with good results. I really hate the idea of an automatic GTR.
Anyway CRD have done TH400 on GTR like JUN II with 4WD so it is possible.
I think CRD and Maatouks can both supply a TH400 and the necessary gear to install the box.
the actual set up of it is the tricky bit, I would only go auto if it was going to be setup by one of the guys who have runs on the board to make it all work.
Just the usual multiplate clutch with laggy RB "roughness".. more so in comparison to an auto. Setting it up would be alittle tricky although it looks like some shops just manage to buy a combo from Als raceglides and with afew converter tweaks its running 7s/8s haha
I would suspect those guys who setup and run 7s and 8s have been playing and tweaking with converters for years. I would be cautious of thinking a newbie could replicate.
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
