I recently bought an R33 gtst with series 2 RB25DET. I turned the boost down on my manual boost controller when I gave it an oil change now whenever It hits boost or even half throttle it will misfire and WON'T STOP at all... Check engine came on after oil change
Has link g4 440 injectors bigger turbo 42mm wastgate and straight pipe... Tuned to 240kw on 15 psi
Changing coil packs and sparks this week.. any help appreciated thanks
https://www.sau.com.au/forums/topic/477087-rb25det-misfire-under-loadboost/
Splitfires are not expensive now. They are the same price as they have ever been, possibly cheaper in real terms. They are still the cheapest & easiest way to do a coil upgrade.
They are, however, not really any different in terms of performance & quality than the original Nissan ones, which have been popping up here and there over the last few years. The problem with buying "OEM" ones is that they are probably easier to counterfeit.
The smart approach these days is to replace with a modern pencil coil. Your choices are to buy a kit that uses Toyota/Denso coils (such as Yaris, or any of the 1ZZ tyes) and necessary wiring adaptation & mounting bracket, or to buy Nissan type (R35 GTR, VQ370 types) and the necessary stalk adapters and mounting plate. The Toyota options are cheaper as kits. The easiest/best Nissan options will cost you over $1k, but are the absolutely f**king duck's nuts in terms of performance capability, for a coil that can fit in the factory spot.
Edited by GTSBoy
  • Thanks 1
2 hours ago, BASHERnissan said:
Split fires are so expensive wow
Not really, $600-odd for bolt in is good. When you compare it to cheapo red/yellow ones, yes, but they're on par with OEM and cheaper than the R35 route.
In the mean time, gap your spark plugs to 0.7mm and see if that makes a difference.
Dead coil packs affect the whole range....not just higher up.  Red is dead, Blue is true.
If you don't believe us, take the coils and get them tested.
Otherwise take it to a workshop and get their input.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
