Hi All,
After some Tech info,
R33 S1 GTST Sedan Auto,
My radiator Is Leaking so I am chasing down a replacement , I am on top of that, I have one lined up,
Just Checking to see if people know if following images are of a trans cooler? there are 2 hoses going into the base of the radiator and then around to this cooler,
is this cooler enough for a daily driver? or is an upgrade required? if it is even a trans cooler,
The radiator I am looking at is an all alloy one with no spots for the hoses for the trans oil,
FYI I plan to convert to Manual in the not so distant future,
Thanks in advance,
Matt,
https://www.sau.com.au/forums/topic/477358-auto-trans-cooler/
You need a heat exchanger in the radiator because its primary function is to raise the temperature of the atf to optimum operating temperature and only when that is exceeded will it act as a cooler.. Some cars will not change into top gear until this happens (not sure about your particular car).
If you really are going to convert to manual soon then just take your radiator to a radiator shop and get it repaired. The tiny cooler out front will not do very much on its own.
In my case I just got a bigger (thicker) OEM type radiator and when I went manual just blocked off the heat exchanger. If you are going for serious power then you will probably run an oil cooler anyway.
Thanks That makes things so much clearer!
Ill Price up getting it repaired I need my car 4 out of the 5 days a week so if its too expensive ill have to work out if its worth it for that top gear,
I have always wanted to do the Manual conversion im getting closer to that stage every day now,
Just check that that cooler out the front is actually in the transmission cooling lines and is not actually the power steering cooler. I'm not too familiar with what they look like on R33s, but on R32s, the auto fluid only went through the bottom of the rad and the power steering cooler was just a loop of pipe out in front of the radiator. Not a proper finned heat exchanger like in your photo, but not a lot different in size. Is there a separate loop of pipe out there somewhere for your PS?
On the S1 Stagea (R33 engine) the trans cooler looks like the one in the picture. On the S2 (neo engine) there is a proper trans cooler like the PWR kit (rectangular). So some of the S1 guys (such as SK) uprated the trans cooler and used the original one for the power steering.
I went even more baller and used the R34 Neo trans cooler as my PS cooler!
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
