  • 6 months later...
  • Replies 99
any chance of getting just the filter element?....I already have a unifilter trumpet, but the foam filter is starting to deteriorate.
G'day Duncan,
I'd like to order one kit for an R32, are they still available? What do I have to do?
Cheers.
Isn't this just the UAS kit??? cost about 350 from NSW??
The UNifilters are awsome, I have one on all my cars...and the box form UAS is the same but comes in Plastic/Metal/CF
Hi khunjeng, this group buy is direct from unifilter. UAS presumably buy the same or similar kit from Unifilter, add a margin then resell it.
R32 RB25, pm sent :P
Hi guys, no exaggerating the Unifilter Product by i was up there the weekend before this was put up, and man does it make a far amount of difference on my r32 GTS-t. Its a stocker and just with the filter and box my blow off valves sounds heaps better and is noticeably torquer at low end revs.
Cheers
  • 1 month later...
Hi mate, somewhere between 20-30 people have purchased the kits with the SAU discount over 2 years, let me know if you are interested :spank:
could you please PM me with the price including delivery to just near brisbane, i am definetly interested in buying one.
just one thing in the posts i read that the shields without the top part give better performance is this true??
thanks
  • 1 month later...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
