I'm trying to install a new head unit into my 92 GTST, I got the until in but I'm not getting anything from the speakers, I'm pretty sure I have it hooked up right but I read somewhere that the amp in the boot wont operate with a new head unit. I'm trying to avoid rewiring all of the speakers but I'm pretty new to the audio world and any help would be much appreciated.
https://www.sau.com.au/forums/topic/477938-head-unit-install/
Sorry to hear you're having troubles.
We're probably going to need more to go on than what you have here. A couple of pics and a hand drwwn diagram would be awesome and also the make and model of your amp and head unit.
Are you getting power to both the amp and head unit right now? And if so what voltages do you see?
I have power at the head, unsure about the amp I will check it when I get home from my little trip. I have 12 volts and a 5v reference at the head. This is the reference I used to write the head unit. It's a lower model kenwood head unit. Not sure of the particular model right now. I ran into this issue then had to leave for a small work trip.
Edited by Digdug154
  • Like 1
35 minutes ago, GTSBoy said:
There are wires that run from the console back to the amp. These can be made to connect to speakers instead.
But FWIW, just get the seats out of the car and put some new speaker cable in.
The stock working doesnt look too good I agree, but I'd  rather do that during winter when I dont want to drive this car. Right now I just want some tunes while I'm cruising this season
It's possible the car has the "active speakers" still in the car? Then an aftermarket headunit wouldnt work with the system, since both front speakers and the rear speakers are controlled by individual amps.
The front speakers were an easy replacement, the rear amp can be bypassed pretty easily as well
Edited by Hcr32typem
Yes it does have active speakers! How do I bypass those amps properly?
The front speakers should be pretty straight forward the rear takes some cutting and splicing. I'm trying to find the guide I used to bypass the rear amp that runs both rear speakers.
Found the guide I used.
I used crimable caps to seal the wires together, left the rest of the plug intact so that I wouldnt have any potential crossed wires. Works fantastically.
I'm running 4x6 in the front and 9" in the back. They're just cheap Dual speakers (cheap American brand) but they sound fantastic compared to the originals whose membrane had disintegrated like 10 years ago haha
4 hours ago, Hcr32typem said:
saudering iron
Now, it's one thing for you Yanks to say "soddering iron" (when it is spelt soldering, and said with the L pronounced like in the word "older", by the original architects of the language, and us Aussies), but it is another thing entirely to spell it the way you weirdos say it! Did you make up the spelling "sauder", or is that actually how some/all of you write it also? If so, where the hell did it come from?
  • Like 1
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
