Just now, ActionDan said:
See, diesels are shit ;)
Ha ha.  Having started my apprencticeship doing valve clearances on Holden Rodeo's I do tend to agree on old (ie Toyota) technology engines.  I forget all my hate when you see what a modern one can do.  We've delivered 3 Audi SQ7's this year with the 320kW 900Nm diesel V8 in them.  Now THAT is a diesel engine it's hard to hate on!  Sounds good, goes good and surprisingly good fuel efficiency if you realise the throttle isn't an on/off switch.....
  • Like 1
Mine is only a GXL so it's just airflow in there, will be AC if you have it on, but it's not an actual fridge like Kak/VX.
What year model did you have, wanna know if it was the same as my current one so I know how shit it's gonna be towing 2T lol
I'd be tempted to drive it... just to check it out you know ;)
I've looked at Q7s lots of time for some reason.
I've got an SQ7 on a boat docking in a few weeks.  Not far from Albury to Shepparton.....
Ahh, yeah 120s were down 20-30kw's on the 1GR used in mine, plus mine is tuned/intake to help a bit.
Still slow, just not "as" slow.
The 3L piston breaker is f**king anemic and couldn't pull the skin off rice custard.
A v12 would be sexual.
I do get down to Shep a bit for work, are you down that way?
Well well, V6 Amarok...
Proper overpriced european shitbox with stupid parts and service pricing. The upside is you can look like a king at the job site along with you "Unit" sticker across the back window.
I towed with a new Dmax to an undisclosed location recently with a car on the back and 1200kg trailer, did it well even with boxes on the back.
A Camry will tow 1200kg lol
New Dmax at least looks better than the old one, nfi about how good it is.
A mate has a DMAX for work and an MUX for home and loves them both. I tried MUX, good value, but drives like a ute.
1200 + 1600kg car..
Dmax is basic but I would own one over a Ranger......
2 minutes ago, ActionDan said:
I was just thinking that...
Didn't you start the tow thread originally?
Why is your convertible barbie car going to be on the Haltech series and what ep.
Like, share and subscribe to find out.... :D
  • Thanks 1
  • Haha 2
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
