MizarP Posted August 28, 2019 Share Posted August 28, 2019 Hello All, I have a quick question, I just bought some wheels for my 4door skyline, they’re 17x8 +30 and the website I bought them from (figment industries) has a thing where you put your car model in and if it has stock brakes suspension etc in it and it gives you wheels that SHOULD fit. I bought the wheels and when I went to put on the front ones, the wheel spikes hit on the front STOCK brake calipers. I was wondering if anyone else has had this problem and if so how can I fix it or what wheels do I need to get/ specs so the spokes clear the caliper. My stock wheels already are very close to the caliper as is so I’m kind of lost as to what to do. It seems the stock caliper in the front are huge! Thank you guys, I also know that people have put rpf1’s on it because I’ve seen pics of gtst’s with them but idk what specs to get to have them not hit on the spokes Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/ Share on other sites More sharing options...
GTSBoy Posted August 28, 2019 Share Posted August 28, 2019 You need a small slip on spacer (at minimum), or a bigger bolt on spacer (because safer) to push the wheel out. But spacers are not a better idea than better wheels. RPF1s fit fine. 17x8 +35 fit with plenty of clearance to the spoke. 1 Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914625 Share on other sites More sharing options...
MizarP Posted August 29, 2019 Author Share Posted August 29, 2019 57 minutes ago, GTSBoy said: You need a small slip on spacer (at minimum), or a bigger bolt on spacer (because safer) to push the wheel out. But spacers are not a better idea than better wheels. RPF1s fit fine. 17x8 +35 fit with plenty of clearance to the spoke. Thanks for the reply! So just to be clear the rpf1’s would clear the brakes? And if I was going to go with spacers I would go with the ones that bolt on and have their own studs but the only thing that scares me about that is that the wheels would poke out too much and rub on the fenders, thoughts? Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914632 Share on other sites More sharing options...
GTSBoy Posted August 29, 2019 Share Posted August 29, 2019 Spacers are shit. A bolt on is safer, but will definitely push the wheel out at least 10mm, probably 15 for the smallest ones you could get. a 5mm slip on would be the least change to wheel position, but slip ons are not a great idea. RPF1s definitely fit. The above spec I posted is what is on mine, and they have fit R32 brakes, R33 brakes and now R34 brakes. 1 Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914636 Share on other sites More sharing options...
MizarP Posted August 29, 2019 Author Share Posted August 29, 2019 3 minutes ago, GTSBoy said: Spacers are shit. A bolt on is safer, but will definitely push the wheel out at least 10mm, probably 15 for the smallest ones you could get. a 5mm slip on would be the least change to wheel position, but slip ons are not a great idea. RPF1s definitely fit. The above spec I posted is what is on mine, and they have fit R32 brakes, R33 brakes and now R34 brakes. Oh ok thank you! Do you also have huge brakes in the front ? Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914637 Share on other sites More sharing options...
GTSBoy Posted August 29, 2019 Share Posted August 29, 2019 R34 brakes are not huge. Same Sumitomo caliper, just with longer mounting legs, on 310mm rotor. Much better than R32 @ 280mm though. Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914658 Share on other sites More sharing options...
niZmO_Man Posted September 2, 2019 Share Posted September 2, 2019 Those wheels aren't Enkei, they those Chinese made copies no? Why not get genuine ROTA? Or better yet, non-stuffed wheels made by original manufacturer? But yeah, spacers are illegal. Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914944 Share on other sites More sharing options...
MizarP Posted September 2, 2019 Author Share Posted September 2, 2019 8 minutes ago, niZmO_Man said: Those wheels aren't Enkei, they those Chinese made copies no? Why not get genuine ROTA? Or better yet, non-stuffed wheels made by original manufacturer? But yeah, spacers are illegal. No they aren’t Chinese made copies and they costed a little more than rpf1’s matter of fact (should’ve just gotten rpf1’s I know). I just need to know if 17x8 +35 rpf1’s will clear the stock brakes, the user above already said they would so I’m gonna go with them and cross my fingers and hope they work Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914948 Share on other sites More sharing options...
niZmO_Man Posted September 2, 2019 Share Posted September 2, 2019 Wait what? RPF1 are like $1,500 for a set. Why would you get copies with unknown QC? But hey, your car and life. Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914949 Share on other sites More sharing options...
MizarP Posted September 2, 2019 Author Share Posted September 2, 2019 1 minute ago, niZmO_Man said: Wait what? RPF1 are like $1,500 for a set. Why would you get copies with unknown QC? But hey, your car and life. I just said they’re not copies. And no the ones I got ended up being around 1.2k and the rpf1’s were 1k for the set. Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914950 Share on other sites More sharing options...
niZmO_Man Posted September 2, 2019 Share Posted September 2, 2019 Okay. Why did you talk about RPF1 then? What are these mysterious wheels? Cosmic yeah? Where are they made? What's the background of the manufacturer? What standards/testing do they do? $1k wheels clears 4 pots and has a long history, or $1.2k wheels that doesn't clear brakes is made where? Doesn't matter, you already bought them. RPF1 easily clears 4 pot brakes. A mate bought a set for his Evo8. Sounds like you're from USA though, 20mm bolt on spacers and maybe an AR1 rifle should do it. Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914952 Share on other sites More sharing options...
MizarP Posted September 2, 2019 Author Share Posted September 2, 2019 Just now, niZmO_Man said: Okay. Why did you talk about RPF1 then? What are these mysterious wheels? Cosmic yeah? Where are they made? What's the background of the manufacturer? What standards/testing do they do? $1k wheels clears 4 pots and has a long history, or $1.2k wheels that doesn't clear brakes is made where? Doesn't matter, you already bought them. RPF1 easily clears 4 pot brakes. A mate bought a set for his Evo8. Sounds like you're from USA though, 20mm bolt on spacers and maybe an AR1 rifle should do it. No need to be so condescending. They said theyd trade out my wheels for the rpf1’s and was just looking for confirmation that they’d fit. Thanks for all your help. Be nicer. Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914953 Share on other sites More sharing options...
niZmO_Man Posted September 2, 2019 Share Posted September 2, 2019 Okay, cool. Why defend the crap wheels then? Link to comment https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/#findComment-7914954 Share on other sites More sharing options...
