For Sale: R32 GTR Parts, Panasport G7 C5C 18 x 10.5, WORK MEISTER S1 3P18 X 10.5 +12, RB26 Head, BM50 MC, Series 2 R32 GTR Dash
G'day,
Clearing out the shed and shoring up some cash for the next run of mods.
A set of 4 x Panasport G7 C5C 18 x 10.5 + 15, These have been freshly refurbished and are in mint condition as per the pictures below not a scratch, mark or blemish.
$3,500 ex Perth
68752488_450534225534956_8213325320883798016_n.jpg.a7e9e694ad700363d8ab61b3bcdb8e96.jpg
68496477_2550136228547384_8288051292203384832_n.jpg.c83a2c51dbabc036a1270ea9c111d1de.jpg
69522547_2523380887894777_8111412292479877120_n.jpg.04f8ebccb391e706db314957e67bede9.jpg
30703915_10157331757514832_2664101233693818880_o.thumb.jpg.3fe2c852ae8f56733ced8ac19c0d8492.jpg
How they looked pre refurbishment in white on a R32 GTR
16865071_10155895961784832_5555189007059383208_n.jpg.b33d33624678cc1b3e473b177ccbe812.jpg
WORK MEISTER S1 3P 5-114.3 MBL 18 X 10.5 +12 R DISK - MATT BLACK CENTER DISK, GLOSS BLACK ANODIZED LIP, CHROME RIVETS, bought at Christmas
As new, minor blemish as per photo on one wheel, with 265/35/18 AD08s with 65% left on them. $3,250 ex Perth can do sans tyres for $3,000
Photos don't really do it justice, so here is a video walk around
RB26 Head it currently has HKS 272 cams, Kelford Beehive springs, Tomei Cam Caps and the machining to suit, selling as I am going shimless due to popping shims at 825whp @ 2.0 bar with flat shift engaged due to my holinger.
$4,000 ex Perth
R32 GTR SERIES 2 180kph dash 97000kms
No broken clips
$250 ex Perth
66396682_10158672220644832_7245391253171339264_n.jpg.adcfacd7f0df8d5822668822e8373b32.jpg66483226_10158672220779832_5580881535214551040_n.jpg.ca846c2bcb4dd85b76f7eb98c880fb7f.jpg
R32 GTR Aircon Setup - working when removed, I am pretty sure it is a new condensor however it was a long time ago when set up so selling as if used as I cant find evidence verifying that.
All is there as removed, Compressor, condenser, condensor fan, brackets, hoses lines etc. Not keen to separate.
$600 the lot ex Perth
69351763_10158819875484832_1359705410902163456_n.thumb.jpg.06eaf6ecf647785e9717a12b65066907.jpg
69433398_10158819875714832_8106520745636528128_n.jpg.c44b503d1c829f5f1a37a261d05be42f.jpg
69597961_10158819875614832_5293745546794631168_n.jpg.89ec3f991cfe7c179488c052e6faa134.jpg
69647001_10158819875849832_2993975986409701376_n.jpg.a6b10c00939dd12ad00949af6c48be25.jpg
Genuine BM50 master cylinder, Bought at Christmas for some reason as opposed to a BM57, have upgraded to a BM57 so is surplus to my needs.
$250 ex Perth
69223411_10158819872034832_6864618316204343296_n.thumb.jpg.78486ddd791690081dcc60c6acf4af94.jpg
69235150_10158819872244832_8061173115125760000_n.thumb.jpg.513a292df621d659d731f7ed5040d0c1.jpg
69701191_10158819872354832_6323845164422922240_n.thumb.jpg.08b57e37bf3b64489662a8f03d365444.jpg
Negotiable on most things, but don't be a total sock.
Willing to ship interstate and international.
Cheers!
Hi, just wanted to ask about the speedo. Series 2 would mean that it has the blue circuit on the back correct? Thanks
I’m surprised that speedo still worked after you had it - seeing as it only goes to 180km/hr Damo!   ?
needle wasn’t bent?
  • Like 2
needle wasn’t bent?
dash is sold gorgeous
xoxo
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
